1977 924 rough idle/stalls
jonny924
PostPosted: Tue Aug 05, 2008 7:03 am    Post subject: 1977 924 rough idle/stalls Reply with quote
Just got this car has been sitting, installed new fuel pump and plugs, cap, rotor, and fresh fuel. Car will start and idle nice for about 3 sec and start to spudder and then dies, will restart and do the same thing. Checked timing and adjusted should be really close but no change..-- Also has no throttle response if you go to give some throttle wants to bog and die out..
Need some help please - thanks to all who do
PostPosted: Tue Aug 05, 2008 7:46 am    Post subject: Reply with quote
Agent jonny924, your mission if you choose to accept it, (and you should) is to replace all rubber vacuum lines in the engine compartment.
PostPosted: Tue Aug 05, 2008 9:29 am    Post subject: Reply with quote
It will listen to the Hound of Plaid, or it will suffer. Yesssss. . .
968rz
PostPosted: Tue Aug 05, 2008 11:57 am    Post subject: Reply with quote
Also do a search here for AAV, cold start valve and fuel pressure test.
Rick
79 924 coupe Petrol Blue 3spd auto (wife's DD)
93 968 coupe Amazon Green 4spd Tip (my DD)
PostPosted: Tue Aug 05, 2008 9:55 pm    Post subject: Reply with quote
Even before that, I'd pull injectors and make sure they're spraying... I'm betting the fuel distributor may be gunked up...
