Did 924S's and 931s come with LSDs?
Squeaky
PostPosted: Sat May 03, 2008 5:46 am    Post subject: Did 924S's and 931s come with LSDs? Reply with quote
If so, were they 1 way or 1.5 way? Viscous or clutch? Any other info is appreciated.
Squeaky
PostPosted: Sat May 03, 2008 1:13 pm    Post subject: Reply with quote
21 views and NOBODY knows?
PostPosted: Sat May 03, 2008 2:29 pm    Post subject: Reply with quote
Some did as a factory option but are as rare as rocking horse shit.
Clutch.
Search feature above using term LSD, etc will reveal more info.
Khal
PostPosted: Sun May 04, 2008 4:12 am    Post subject: Reply with quote
Most of this information has previously been posted, in considerable detail. You should really learn to search before starting a new thread for every thought you have.
It's not that we mind answering questions, I just wanted to point out that nearly all the info you have asked for is already available and would probably only take a few moments to search it out...
'80 924 Turbo
Squeaky
PostPosted: Sun May 04, 2008 7:50 am    Post subject: Reply with quote
I don't find the search as effective as asking a straight-forward question an getting a direct answer.
PostPosted: Wed May 14, 2008 7:13 am    Post subject: Reply with quote
Well, in the category of better late than never, this article might shed some light on your question (courtesy of Steve B aka "bass gt").
PostPosted: Wed May 14, 2008 9:43 pm    Post subject: Reply with quote
951 LSD will swap right in... with 8 hrs of pro Porsche mechanic shop time.
Stock is a clutch pack, 40%, but can be changed with re-shimming.
bass gt
PostPosted: Thu May 15, 2008 1:57 am    Post subject: Reply with quote
Vaughan,
You're spot on of course, but i found the 944 box ratios to be a nightmare. Fine in 1st to 4th, but 5th is in another galaxy!!! Something like 52 mph diference from 4th. All other gears are spaced at about 32mph. I wondered why i couldn't pull 5th properly on the long tracks!! The reason i will use the 968 box is not so much for the 6th gear, but all gears are very equally spaced at 32-34mph. So even if i never use 6th, at least i will have a useable 5th!!
And regarding the 951 LSD, i would be amazed if the plates are still servicable after all this time. Whats the cost of new plates & springs??
Steve
Front Wheel Drive is the Devil's work.
PostPosted: Thu May 15, 2008 3:56 am    Post subject: Reply with quote
I dunno, haven't rebuilt mine, just used heavier oil...
PostPosted: Thu May 15, 2008 4:23 am    Post subject: Reply with quote
We are here to serve, O Liege.
gegge
PostPosted: Thu May 15, 2008 5:28 am    Post subject: Reply with quote
Please explain. You are saying that a 951 or Audi V8 will fit into a 016 box I guess, since both are Audi? Will not fit into G31 I presume( then you need a 915)?
Carl Fredrik Torkildsen
Raceboy
PostPosted: Thu May 15, 2008 4:27 pm    Post subject: Reply with quote
951 one will swap right in without any additional work required, but Audi V8 needs dealing with the bearing issue.
Yes, G31 needs either 915, 930 LSD (confirmed), or G50 (NOT confirmed).
'83 924 2.6 16v Turbo, 470hp
'67 911 2.4S hotrod
'90 944 S2 Cabriolet
'78 924 Carrera GT replica
'84 928 S, sold
'91 944 S2, sold
'82 924S/931 "Gulf", sold
'84 924, turbocharged, sold.
