924er
Joined: 10 Jan 2006 Posts: 339 Location: Los Angeles California
Posted: Sat May 10, 2008 7:09 pm Post subject: Sudden loss of power |
So I got all the vacuum lines properly connected as well as the timming done after the engine rebuild and i notice sometimes the car would just loose power then come back then lose power again and its wierd, its like 3 out of 4 cylinders are firing so im guessing no spark. the spark plug wire recently changed because i had this problem before and it was a bad wires or dist, rotor. these wires still look good, i mean it does get pretty hot in there with the wires just carelessly hanging there. has anyone ever had this problem before?? what else could this problem be????
this was one of the reasons my car didnt pass smog emissionss because it was too weak for the dyno to read it so the guy didnt know what to tell me haha
but thanks for the help... _________________ 80' Porsche 924 NA - Slower then a S L O W
86' Porsche 951- New toy |
Ozzie
Posted: Sat May 10, 2008 8:40 pm Post subject: |
Fuel filter blocked? _________________ Porsche 924 1984 (UK import) NA
Its AUTO and its BLACK
Montego Black on black/red
Posted: Sat May 10, 2008 9:02 pm Post subject: |
What spark plug wires are you using?
Is your distributor cap/wires hitting the hood? _________________ White 87 924S "Ghost"
Joined: 29 Jul 2001 Posts: 9081 Location: Royal Oak, MI, USA
Posted: Sat May 10, 2008 10:47 pm Post subject: |
Spark plug wire condition has nothing to do with their appearance... _________________ Vaughan Scott
924er
Posted: Sun May 11, 2008 3:06 am Post subject: |
Fuel filter is new,
| Quote: | What spark plug wires are you using?
im using some generic brand from autozone
| Quote: | Is your distributor cap/wires hitting the hood?
I dont think its hitting my hood, its where it is supposed to be but ill double check...
how often have you guys had to change your wires???
i found NGK wire set at rockauto.com for $20, thats cheap does that mean you get what you pay for on that one? i thought NGK was name brand _________________ 80' Porsche 924 NA - Slower then a S L O W
924er
Posted: Sun May 11, 2008 5:14 am Post subject: |
Fuel filter is new,
I dont think its hitting my hood, its where it is supposed to be but ill double check...the hood was open at the smog dyno
i found NGK wire set at rockauto.com for $20, thats cheap does that mean you get what you pay for on that one? i thought NGK was name brand[/quote] _________________ 80' Porsche 924 NA - Slower then a S L O W
Posted: Sun May 11, 2008 8:12 am Post subject: |
Use only THESE unless you like replacing them. Some places guarantee this set for the life of the car. This set has the proper heat shielding. _________________ White 87 924S "Ghost"
924er
Posted: Sun May 11, 2008 3:14 pm Post subject: |
yeah i bet those are better since its brand name, ill place an order but ill wait a couple of days because it hasnt been losing power today although i did not drive it until the engine got too warmed up because that is when it usually loses power so ill see what happens and let you know thanks paul _________________ 80' Porsche 924 NA - Slower then a S L O W
Posted: Sun May 11, 2008 10:41 pm Post subject: |
Tell me more about this statement:
"this was one of the reasons my car didnt pass smog emissionss because it was too weak for the dyno to read it so the guy didnt know what to tell me." _________________ White 87 924S "Ghost"
924er
Posted: Mon May 12, 2008 4:35 am Post subject: |
i dont know for some reason when the tech at the smog shop would throw it in 2nd gear it would nearly stall because their is not enough power to roll the dyno basically because one of the cylinders are not working. i did not know that at the time so the tech was confused and played with a few things, used his timming light but didnt know whats wrong, until i drove it home and realized the problem. it actually helped pushing the wires in because i found one of them kind of loose and that fixed the problem for now. i havent drove it too much but so far so good, if the car looses power again like that i will probably buy the bosch wires/cap/rotor/plugs _________________ 80' Porsche 924 NA - Slower then a S L O W
924er
Posted: Mon May 12, 2008 9:02 am Post subject: |
ok well i took the car for a long spin and after a while i lost most of the power until i went home. so im guessing the cheap aftermarket wires i have cant resist heat no more, so i purchased the bosch brand..free shipping
Is it possible it could be something else other then the wires?
thanks.... _________________ 80' Porsche 924 NA - Slower then a S L O W
Posted: Mon May 12, 2008 9:15 am Post subject: |
Some possibility of a bad coil, though I haven't heard of it happening with a 924. An old '74 Dodge van I once had would run worse after it heated-up - the problem turned out to be a bad coil in that case. _________________ "..it's made in Germany. You know the Germans always make good stuff."
Posted: Mon May 12, 2008 10:59 pm Post subject: |
Seems like an obvious thing to put new plugs in there with the wires... but get good ones, Bosch or NGK (yes IMO they are good) - but not Champion, Delco, or other domestic junk... or Splitfires or other gimmick ones either... _________________ Vaughan Scott
924er
Posted: Tue May 13, 2008 10:47 am Post subject: |
yep i ordered bosch but thanks for all the help ill let you know if that fixed my problem, because it only occurs when the engine is warmed up _________________ 80' Porsche 924 NA - Slower then a S L O W
924er
Posted: Thu May 15, 2008 9:49 am Post subject: |
ok so i got the wires in the mail today, installed them already and came back from a nice long driver, the car sustained full power the whole way, the idle is nice too, everything is fine... thanks for all the help guys!
now lets just wait for the next problem to come  _________________ 80' Porsche 924 NA - Slower then a S L O W
