andytuks
Posted: Tue Apr 22, 2008 10:00 pm Post subject: Water pump help??? |
Hey, No water comes thru when i try to clean my windscreen, does this mean that my water pump is broken?, is it a serious problem, easy to fix?
hope you know what i mean.... thanks |
Posted: Tue Apr 22, 2008 10:12 pm Post subject: |
can you hear it buzz when you pull the lever ? _________________ Supercharger and EFI kits
https://www.the924.com |
Joined: 04 Dec 2002 Posts: 767 Location: Blyth, Northumberland, UK
Posted: Tue Apr 22, 2008 10:25 pm Post subject: |
*if* you can hear the pump then chances are the nozzles or the little plastic non-return valve are just blocked, could also check the end of the pipe inside the bottle, it could be clogged there. _________________ Mars Red '78 Euro 924 n/a
http://www.cardomain.com/id/5150_uk
Graphite? Grey Metallic '85 (late model) 944 2.5
There are two kinds of pedestrians: the quick and the dead. |
Rich H
Posted: Wed Apr 23, 2008 12:54 am Post subject: |
Bypass the non return valves  _________________ 1994 Lotus Esprit S4 - Work in progress...
Posted: Wed Apr 23, 2008 5:07 am Post subject: |
I had 2 problems that needed fixing with mine. 1) the elect. connection at the pump needed cleaning and 2) the "non-return" valves were blocking flow in both directions. You can get by without them - just need to wait a little longer for the fluid to come up the line. -But of course that's better than not having to wait so long, and then getting nothing out of the squirters.  _________________ "..it's made in Germany. You know the Germans always make good stuff."
Martijnus
Posted: Wed Apr 23, 2008 8:14 am Post subject: |
but the pump is working then? mine doesn't do anything... guess it's the wiring but haven't got that high on my prioritylist. _________________ "Rule: Turbo's make torque, and torque makes fun." (C. Bell)
924 "50-jahre", 1981.
MSII/extra, LPG, ITB's, 5lug.
To be turbo'ed in a while.
bcblase
Joined: 23 Oct 2007 Posts: 574 Location: Winchester, VA
Posted: Wed Apr 23, 2008 2:29 pm Post subject: |
Check the hoses for kinks too - they seem to like to kink up where the hose bends when the hood is shut. My pump was buzzing good, but no fluid was coming because of the kink that only blocked the flow when the hood was shut.
I also bought an extra pump just for safe keeping.
BC _________________ 1987 Porsche 924S - track toy
1986 Mercedes 190E 2.3-16v - autocross
2007 F-150 5.4L Lariat Supercrew - tow beast
1994 Volvo 850 Race Wagon - 24 Hours of Lemons Car
2001 BMW 325xi - daily driver |
