will 944 wheels fit on 924 turbo ?
PostPosted: Thu Nov 22, 2007 8:03 pm    Post subject: will 944 wheels fit on 924 turbo ? Reply with quote
Will 944 wheels (15" 7J phone dail wheels) fit my 924 turbo (79' 5-stud) without the use of spacers ?
PostPosted: Thu Nov 22, 2007 10:50 pm    Post subject: Reply with quote
There are two types of 944 'phonedial' wheels. If you select the up to 85.5 year models then they are a straight bolt on fit - the early 944s after all had identical suspension to 924Ts. Another straight bolt on fit are 'cookie cutters from the same years.
Maxx
PostPosted: Fri Nov 23, 2007 1:33 am    Post subject: Reply with quote
No, wheels from an early 944 will not fit on a 924 turbo. Wheels for a 924 turbo have an offset of 52 mm and wheels for 944 before -87 has an offset of 23 mm (944 has a wider track!).
Wheels from -87 and later, with a higher offset, will fit perfectly.
//Maxx
PostPosted: Fri Nov 23, 2007 2:27 am    Post subject: Reply with quote
So I need phone dail wheels from a 944 type 2 ? Sure ? And do the exist in 15 inch ?
PostPosted: Fri Nov 23, 2007 4:47 am    Post subject: Reply with quote
just pay attention to the offset as maxx stated, you'll be fine, and yes they do come in 15 (on my 924S)
PostPosted: Sat Nov 24, 2007 12:24 am    Post subject: Reply with quote
Sorry guys - you are so right. Too late at night when I wrote that. Just got so excited - kinda like premature vocalisation. Only had to walk into my workshop to confirm. Forgot that operative word 'spacers'. Mea Culpa.
Cheers Pete
PostPosted: Sat Nov 24, 2007 2:59 am    Post subject: Reply with quote
after some research:
924 turbo 15x6J offset 53 (spiderweb wheels)
924 S phone dail 15x6J or 15x7J offset 52,3
944 I phone dail 15x7J offset 23,3
944 II phone dail 15x7J offset 52,3
So I need 944 II or 924 S, of course I will look for the wide 7J ones.
Does 944 II have a different offset front/ rear ?
PostPosted: Sun Nov 25, 2007 4:06 am    Post subject: Reply with quote
I think some had an offset of 10 in the rear (turbo? S?).
PostPosted: Sun Nov 25, 2007 10:13 am    Post subject: Reply with quote
All the late model 87+ 944s had 52.3mm offset front and rear.
Raceboy
PostPosted: Sun Nov 25, 2007 4:57 pm    Post subject: Reply with quote
Early offset 944 wheels fit just fine on 924 Turbo, of course it depends on the width of the rim/tire.
'83 924 2.6 16v Turbo, 470hp
'67 911 2.4S hotrod
'90 944 S2 Cabriolet
'78 924 Carrera GT replica
'84 928 S, sold
'91 944 S2, sold
'82 924S/931 "Gulf", sold
'84 924, turbocharged, sold.
PostPosted: Sun Nov 25, 2007 6:32 pm    Post subject: Reply with quote
Well I want 7J wheels, the 6J spiderweb wheels are to small for my slicks.
I think the telephone dail 944 S2 wheels will be the best option for track use, don't you think ?
I want to stick to 15" because I have all my slicks/ rain tires in that size.
Raceboy
PostPosted: Sun Nov 25, 2007 7:10 pm    Post subject: Reply with quote
On the track you want as much track as you can. In case of 7", early offset wheels should fit fine.
'67 911 2.4S hotrod
'84 928 S, sold
'91 944 S2, sold
patand
PostPosted: Sat Dec 15, 2007 3:31 am    Post subject: Reply with quote
That is correct! I run 15x7" Cookie Cutters ET23 with 205/50-15 R-tires for track use. It fills out the body nicely but you might need some tracksettings (which I have on my car) for the camber for them to stay within the wheelarches.
www.patandracing.se
PostPosted: Sat Dec 15, 2007 7:12 am    Post subject: Reply with quote
I bought a set of phone dail wheels.
front, 15x6J ofset 36 (from 911)
rear, 15x7J ofset 52,3 (from 944 S2)
