Weird Engine Behavior
bcblase
PostPosted: Thu Dec 06, 2007 7:34 am    Post subject: Weird Engine Behavior Reply with quote
Filled the fuel tank about 3/4 full the other day at lunch, and then started driving it home in the evening. About a mile from the office, the car started hesitating and acting very sluggish for a couple of miles. It seemed to clear up and regain power, but then I got the very distinct odor of gasoline (not exhaust) in the passenger compartment for a while.
Any ideas?
BC
1987 Porsche 924S - track toy
1986 Mercedes 190E 2.3-16v - autocross
2007 F-150 5.4L Lariat Supercrew - tow beast
1994 Volvo 850 Race Wagon - 24 Hours of Lemons Car
2001 BMW 325xi - daily driver
JSilverman
PostPosted: Thu Dec 06, 2007 8:32 am    Post subject: Reply with quote
Does the car make power in the upper RPM range? My car acted similar when part of the cat had broken off and blocked the exhaust. Dont know about the gas smell though.
StuckinFlorida
PostPosted: Sat Dec 08, 2007 3:32 am    Post subject: Reply with quote
so is the car running ok now? do you still have the exhaust smell? this will help explain the problem a little more...
By stating that you had just filled up, i'm guessing you thought there might be somethin in the gas, which it very well could be. But if that were the case, the car should not have cleared up a little while later. Bad gas would also not explain the gas smell.
If i'm not mistaken the charcoal canister is located in the passenger fron wheel well, and its a common occurence for them to go bad and leak fumes (there shouldnt be too much liquid in them, if any).
as far as the failing cat goes, wouldnt you also notice a change in exhaust note? or not?
-Jason
copper '78 924
faded red '87 924s
Cone_Eater
PostPosted: Sat Dec 08, 2007 6:09 am    Post subject: Reply with quote
You need to check your fuel lines. If there is a leak it may very well cause your smell and the hesitating. It could also be your fuel filter causing it to run bad during the lower RPM's. Does it run good at higher RPM's?
1988 924S: Koni fully adjustables, Short shift kit, head work, exhaust, K&N, Jacobs ignition, Larger Injectors, Performance Chip, 928 wheels with cooper Zeon tires, Momo interior, Etc.....
If its fast enough to go... its fast enough to blow.
