Posted: Sun Feb 11, 2007 2:16 pm Post subject: |
Stuff some paper towels in those intake ports and the water inlet..... _________________ White 87 924S "Ghost"
20v924
Posted: Mon Feb 12, 2007 1:26 am Post subject: |
They are strong enough as this is how the holbert 924 racer is currently set up. As soon as I can post pics of the car, I will let you guys see. Doc Bundy's car has a 16v 944 motor mounted is this fashion. That's where I got the idea. The steel cross-member is stronger than the alum unit just not as stiff. Fatigue could play in at 200k mi or so if you race everywhere you go. Vibration is the only downside. locktite all hardware! _________________ A person is smart. People are stupid |
Oysteinrb
Posted: Tue Feb 13, 2007 4:30 am Post subject: |
| special-tool wrote: | Oysteinrb - that is the head temperature sensor.
There are 2 of them:
The one you circled is used by the Motronic - note the Bosch connector
The sensor 3 in ches behind it is ALSO a head temperature sensor, but this one is used only for guages.
Behind them at the same height between #2 and #3, you will see a heat shield.
This hides 2 threaded bosses. The rear one is used for the knock sensor on the later 951.
If you are to use 951 Motronic for your supercharger car, you will have knock sensing.
-Lutjen |
What do you mean when you say motronic? Is that the original ECU on the car, or are you thinking a replacement performance fuel injection system?
Oh, and thanks a LOT for the info!
| Paul wrote: | | Stuff some paper towels in those intake ports and the water inlet..... |
Did it just after i finished taking pictures  |
special-tool
Posted: Tue Feb 13, 2007 8:15 am Post subject: |
Yes - all 944s came with Motronic management. _________________ 951 566/485 HP/TQ at the wheels - pump gas
924S GTR conversion project
Honda 250R- PWK 35mm flat slide, 205 static, Boyesen, Wiseco, DG front/back, Uni, 14/42, |
Oysteinrb
Posted: Wed Feb 14, 2007 10:37 am Post subject: |
| i was thinking of going with something like MSII or haltech in fact... gotta read up on those first tho.. |
924convert
Posted: Wed Feb 14, 2007 1:06 pm Post subject: |
| I am going with MS2. I will attempt to go with sequential injection with a cam sensor, and a COPS ignition such as all the new engines have. I have read up on MS alot the past few months, and I plan to purchase one here shortly. |
20v924
Posted: Wed Feb 14, 2007 2:17 pm Post subject: |
The MSII sounds like a good idea.  _________________ A person is smart. People are stupid |
CBass
Posted: Wed Nov 07, 2007 10:47 am Post subject: |
A little update on this saga, I've come up with the 968 engine and it will be delivered pretty soon, going to be using a 951 bellhousing and clutch assembly with my LSD G31.
I've sourced a 944 engine to use for mocking up and possibly for driving while the 968 engine receives some attention prior to swapping. The 944 engine is complete with crossmember and the fabricated bits of the unibody that it bolts to.
Project 924 S3 is back up and running  _________________ '81 931 in various states of assembly |
J1NX3D
Joined: 06 Feb 2003 Posts: 1333 Location: New Zealand
Posted: Fri Feb 15, 2008 12:10 pm Post subject: |
how is everyone going with their conversions?
im currently looking at a 944 engine for my '80 turbo. what would I need to fit it? will i have to get the '44 torque tube and transaxle? obviously i know i'll need to sort out steering and engine mount issues as previously mentioned.
awesome thread! _________________ '86 944 |
spannernut
Posted: Sat Oct 16, 2010 9:55 pm Post subject: |
Are you saying the 944 crossmember won't suit the early 924 ?
surely the crossmembers are the same dimensions ? |
