germ924
Joined: 04 Aug 2006 Posts: 233 Location: chino valley, Arizona
Posted: Mon Oct 08, 2007 10:17 pm Post subject: steering column issues what is wrong and is it common |
my steering column moves up and down about an 1/8 an inche.
very anoying and can't be safe.. Is there a washer that is wore out or something? I tightened up the steer wheel bolt but that wasn't it.
does this make any sense to anyone? |
924guy
Posted: Mon Oct 08, 2007 10:46 pm Post subject: |
there is a (or supposed to be anyhow) a plastic bushing under the wheel, that seats in the upper sterring shaft bearing. these are common to fail/disintegrate after time, and are easily replaced. i believe the 911 part will fit, but do a search here to verify, and get the part number. _________________ Eric
78 924
82 931 SE "smokey"
99' VehiCross
Y2K Honda Insight
Performance by Pasha |
germ924
Posted: Mon Oct 08, 2007 11:49 pm Post subject: |
sounds easy, thanks guy |
924guy
Posted: Mon Oct 08, 2007 11:56 pm Post subject: |
no prob... _________________ Eric
78 924
82 931 SE "smokey"
99' VehiCross
Y2K Honda Insight
steeny
Joined: 24 Nov 2005 Posts: 319 Location: Brisbane, Australia
Mike924
Posted: Tue Oct 09, 2007 4:58 pm Post subject: |
The Automotion website wrote: | This OEM bearing will require professional installation. |
Don't like the sound of that... _________________ 1985 Porsche 924 'Lux', Kalahari Beige (my ex)
steeny
Posted: Tue Oct 09, 2007 8:29 pm Post subject: |
i dont remember how i did it, but i'm certainly not a Professional steering bearing installer.
there might be a very high tension circlip in the way and i think its tight getting everything back together. but it fixed all play at the steering wheel, so its worth the possibility of taking your eye out with a flying circlip. _________________ 1978 924 N/A
she's gone..... |
Posted: Tue Oct 09, 2007 9:01 pm Post subject: |
There are two different ignition housings, the early housing have a circlip holding the bearing in so use some needle nose pliers to get it out, the later '80 up IIRC have the bearing enclosed in the housing and you need to file the edge back a little to knock out the bearing from behind.
When you install the new bearing use a flat blade screwdriver and hammer and pinch in the metal around the edge working from opposite sides when you do to keep the tension even.
Leadfoot _________________ 1981 ROW 924 Turbo -
924guy
Posted: Tue Oct 09, 2007 10:44 pm Post subject: |
a complete bearing change may not be needed, sometimes its just the plastic sleeve that is missing or worn away. it also acts as a bushing or spacer irrc, and sits between the bearing and shaft...
78 924
82 931 SE "smokey"
99' VehiCross
Y2K Honda Insight
Posted: Wed Oct 10, 2007 9:21 am Post subject: |
the bearing is about $8 and the spacer pictured above is about $2 IIRC,
there's also this little insert that fits inside the bearing, on the early ignitions it was hard plastic on the later ignition it was a softer plastic. This secures the inside of the bearing to the shaft. This came with my bearing, it was totally deformed when I pulled the old bearing out...
Nobbi
Posted: Wed Oct 10, 2007 11:43 pm Post subject: |
The up and down play is nothing to worry about.It is no safety issue.
More diff. is the play when you can pull the steering towards you and back!!
Then you have to change the middle part of your steering column.
Nobbi |
autoxman
Posted: Thu Oct 11, 2007 2:42 pm Post subject: |
Nobbi wrote: | The up and down play is nothing to worry about.It is no safety issue.
Nobbi |
Or you might just need to tighten down the nut holding the wheel on... Heh. I'm sure its happened before. _________________ 1995 Acura Integra GSR 4DR (DB8)
1993 Honda Civic DX
1982 Porsche 924 |
Mike924
Posted: Thu Oct 11, 2007 10:16 pm Post subject: |
autoxman wrote: | Or you might just need to tighten down the nut holding the wheel on... |
Is that the driver? _________________ 1985 Porsche 924 'Lux', Kalahari Beige (my ex)
Rich H
Posted: Thu Oct 11, 2007 10:30 pm Post subject: |
Nah, thats the nut holding on to the wheel _________________ 1994 Lotus Esprit S4 - Work in progress...
