brit2514
Posted: Thu Jul 19, 2007 10:22 pm Post subject: clutch options |
i need a clutch for my engine swap. i want to use the 924 box
so i need a 11" friction plate with a 13/16 hub and 24 splines
does anyone have any ideas? |
Una
Joined: 23 Sep 2007 Posts: 30 Location: Port Orchard, WA
Posted: Sun Sep 30, 2007 1:40 am Post subject: |
Might try buddying up with a guy behind the parts counter. What you need is a clutch alignment tool. Take that and start popping open clutch boxes, start measuring discs with a tape measure to find one the diameter you want, and then if it's the right diameter, try to fit your clutch alignment tool into the splines.. That's the cheap route.. Another route would be to email a clutch place online and see if they can simply look one up for you in their database, I've heard http://specclutch.com/ is a good place to deal with. _________________ Brian near Seattle, WA
'82 Porsche 924 |
Posted: Sun Sep 30, 2007 8:04 am Post subject: |
I have an idea. . . Search! _________________ Toofah King Bad
