Email: Webmeister@924.org
Date: 1/31/00
Time: 7:36:50 AMNot a tremendous chance, but still there. The hose to the rear goes to the fuel tank vent line. So you have the potential to get dirt into the fuel system. The hose to the front goes through a vacumn control valve into the intake plenum but after the filter so you are introducing dirt there. Not a lot in either case, still... I would at least connect the two together. If you can find a charcoal canister used you could put it back on. It makes no performance difference. In some locales you may need it for emissions testing.
