isuras2
Posted: Tue Jul 17, 2007 11:07 pm Post subject: Fuel Pressure Check |
I have a fuel injector pressure gauge. I am a little lost as to where to hook it up. I was told at the fuel distributor, but that is it. I was able to connect it to the CSV, but not sure if that is as accurate a spot. I was able to see the fuel pressure while in the drivers' seat though.
Thanks, _________________ Rob
'80 931 (sold)
'80 924 NA (sold)
Former Omaha Crew |
Joined: 29 Jul 2001 Posts: 9072 Location: Royal Oak, MI, USA
Posted: Tue Jul 17, 2007 11:29 pm Post subject: |
I trust you have the CIS type gauge, with the valve in it, right? It should be connected at the top center connection of the fuel distributor, inline with the fuel connection already there, and with the gauge closer to the distributor than the valve. Readings are taken first with the valve closed, then open, giving you fuel delivery pressure then control pressure, respectively.
I think we'll be doing this to Dan B.'s (ideola) car tonight; maybe we'll have time to take a pic or two... _________________ Vaughan Scott
Posted: Wed Jul 18, 2007 2:00 am Post subject: |
Pichas? Of course I got pichas -
and a diagram -
 _________________ "..it's made in Germany. You know the Germans always make good stuff."
Posted: Wed Jul 18, 2007 3:59 am Post subject: |
Good man! _________________ Vaughan Scott
isuras2
Posted: Wed Jul 18, 2007 4:00 am Post subject: |
WOW!!! You guys are fast! Thanks for the pics Smoothie. I'll try checking fuel pressure this evening. _________________ Rob
'80 931 (sold)
'80 924 NA (sold)
Former Omaha Crew |
Ozzie
Posted: Wed Jul 18, 2007 8:39 am Post subject: |
The line to the WUR is the spot.
You need to check system pressure and control pressure.
If you shut of the line to the WUR it will tell you the system pressure and when open will tell you the control pressure. _________________ Porsche 924 1984 (UK import) NA
Its AUTO and its BLACK
Montego Black on black/red
techfx
Joined: 11 Feb 2014 Posts: 25 Location: Pittsburgh, PA
Posted: Tue Jun 10, 2014 4:03 am Post subject: |
Wish I had seen the pics above before pulling out all the piping and coil to get to the WUR. :S
Helpful images for anyone else, though! _________________ 81' 924 Turbo, 02 Golf TDi, 88 Scirocco 16v (RIP)... and the Subaru. |
