Qky
Posted: Sat Jun 23, 2007 3:21 am Post subject: Problem with ignition control unit |
Hi guys.
I'm finishing EFI conversion on my '24!
& have problem with ignition, wire from ignition coil to ign.unit (terminal 15) are heating, and signal on ignition coil (terminal 1) are weak.
Is there any car with same or similar ignition unit for convert? |
Rich H
Posted: Mon Jun 25, 2007 6:38 pm Post subject: |
What ECU are you using?
Megasquirt can control a coil direct I think. _________________ 1994 Lotus Esprit S4 - Work in progress...
Qky
Posted: Wed Jun 27, 2007 2:10 am Post subject: |
| Thanks on replay, problem resolute! |
Mike924
Posted: Wed Jun 27, 2007 5:05 pm Post subject: |
| Qky wrote: | | problem resolute! |
Does this mean the problem's still there or that it's been solved? _________________ 1985 Porsche 924 'Lux', Kalahari Beige (my ex)
Qky
Posted: Wed Jul 04, 2007 7:54 pm Post subject: |
| Mike924 wrote: | | Does this mean the problem's still there or that it's been solved? |
Solved!
Zastava Yugo ICU + distributor (coil) |
Posted: Wed Jul 04, 2007 8:29 pm Post subject: |
are you using a YUGO ECU ?  _________________ Supercharger and EFI kits
https://www.the924.com |
Mike924
Posted: Wed Jul 04, 2007 8:31 pm Post subject: |
A transistor is a transistor...
Probably a Bosch unit anyhow. _________________ 1985 Porsche 924 'Lux', Kalahari Beige (my ex)
Qky
Posted: Thu Jul 05, 2007 4:05 am Post subject: |
| morghen wrote: | are you using a YUGO ECU ?  |
No!
I'm usin fiat panda 1.0 Bosch A2.2 ECU
Sensors: iat, cts, o2 sensor & tps
It's simple for conversion
One map in 27c256 cheep or two map's in 27c512 & switch.
It "regulate" just fuel injection
| Mike924 wrote: | A transistor is a transistor...
Probably a Bosch unit anyhow. |
This one is't Bosch, but ti's same. |
