Bad start when the car is cold
PostPosted: Thu Jan 20, 2000 5:36 pm    Post subject: Reply with quote
Email: sigrunvil@simnet.is
Date: 1/20/00
Time: 5:36:50 PM
I have a 924 ´85, that has 97000 km on it. I have a problem to star the car when it is cold.
Some times it can get very cold here in Iceland .
Please send me some hints.
Best regards George
PostPosted: Fri Jan 21, 2000 7:01 pm    Post subject: Reply with quote
Email: vaughan@vaughanscott.com
Date: 1/21/00
Time: 7:01:29 PM
Well, the first thing I'd check is that the cold-start valve is working; it should spray fuel in as soon as the ignition is turned on.
Usually, if that is working, the engine will at least start, though maybe not stay running, in very cold weather.
If it is not, make sure it's getting current; if that is not the case, check the wiring to make sure no shorts or open circuits, and check the thermo-time switch.
If it is working, and the car fires but won't stay running, check to make sure the auxiliary air valve is working properly - it should be closed shut when the engine is quite cold, and open up as it warms up with the engine. The current supply to it will also cause it to open up by heating the bimetallic element.
However, realize it needs to be quite cold to close fully - stick it in the freezer while the wife isn't looking for an hour or two, then see if you can see through it! ;)
Good luck, write if you need more info or help...
Vaughan
PostPosted: Sat Jan 22, 2000 6:22 am    Post subject: Reply with quote
Email: i97lafr@itek.chalmers.se
Date: 1/22/00
Time: 6:22:28 AM
Hello,
You might also want to make sure that the ignition timing is corretly adjusted. If not, this can surely cause starting problems, in both warm and cold conditions.
/Fredrik
'82 924 Indischrot, Euro spec.
This forum is locked: you cannot post, reply to, or edit topics.   This topic is locked: you cannot edit posts or make replies.    924Board.org Forum Index -> Posts Rescued From the Old Board All times are GMT + 11 Hours
