Posted: Tue Apr 24, 2007 4:31 am Post subject: GT racing sucks |
| I can not vouch for all of GT racings inventory, but the carerra fender flares I bought from them were really quite poor quality. The drivers side looked ok, except for the uneven sanding on the edge that contacts the body, and some ugly chipping along that edge as well. The passengers side was full of hair cracks around the edges, One of which was a very big open crack that went clear through the fiberglass located at the lower rear portion of the flare. THe thickness was generally uneaven, especially apparent along the edges of the wheel well curve. The ratio of resin to glass cloth was also not consistant with the drivers side. In several places loose fibers were sticking out from lack or resin. Several hours laying more fiberglass, and very careful sanding to straighten the edges, gave me useable flares. Im not calling them completely terrible, there just aint 310 dollars there. If I had a choice I would try to find another source for these flares. |
-nick
Posted: Tue Apr 24, 2007 5:38 am Post subject: |
Did you call them to let them know? Fiberglass race panels are not known for high-quality construction. That's come up a number of times with Carrera GT bits. _________________ 1980 931S
1991 964 C4 Cabriolet |
Joined: 23 Apr 2006 Posts: 1650 Location: Sydney, Australia... mate!
Posted: Tue Apr 24, 2007 12:17 pm Post subject: |
Yeah, I concur, I just received a turbo nose piece that came from them and was disappointed with the amount of work I'll have to do to make it usable...
G. _________________ Whoever said you can't buy happiness forgot about Porsche!
69 911 |
Posted: Tue Apr 24, 2007 4:07 pm Post subject: |
FWIW, I ordered some ultra wide body rear quarter panels from AIR (American International Racing), and the quality is excellent. I believe they also have Carrera GT kits available. _________________ erstwhile owner of just about every 924 variant ever made |
PORSCHEV
Posted: Tue Apr 24, 2007 8:22 pm Post subject: |
Part of my motivation of buying Neil's old car was to start producing my own GT kit at a bit cheaper price (I can do that since I have a low over head) $1400.00cdn vs GT's kit at 1850.00 USD
With that being said I am leary due to the fact that the fenders don't fit the doors 100%. The gap is ok, But the the fender sticks out past the door by 4-5 mm. The passengers side is better with a 2mm difference..but thats because the hood gap is too close there. This could be fixed..but it will be alot of work!
If you had problems with actual fibers being at the surface of the part..that was caused by the maker not using enough gelcoat in the mold. When your making a part you need to apply at least 8 mils of gelcoat before you lay your first layer of fiberglass down.
They also could have gotten fibers to the surface by not letting the gelcoat harden/dry properly before laying the first layer. Essentialy pushing it through the soft Gelcoat.
Could you tell if the parts are hand laid or are all the strands of fibers random....if they are hand laid you can see the edge from a "roll" of mat fiberglass. _________________ 1976 924
1978-#53 "D" track racer. |
Posted: Tue Apr 24, 2007 8:48 pm Post subject: |
OK Pocketscience
Was wondering how you were going to get them grilles in a N/A nose. Now I nose.
How much is the glass nose shipped here? Not a good fit or finish or what?
Might have to get some more now.
Roger |
Posted: Tue Apr 24, 2007 9:05 pm Post subject: |
Heh, nice detective work Roger...!
I got the GT gear from a guy in Belgium who bought one then changed tack with his projects. It's never been fitted and is mostly OK, just some rough edges etc as described above. Havent tried a dry fit yet. The nose was cheap but shipping from Belgium was 50 euros...
Can you FG? Do we go halves in those moulds on ebay?
Cheers, _________________ Whoever said you can't buy happiness forgot about Porsche!
69 911 |
NEMESIS
Joined: 29 Jul 2006 Posts: 296 Location: BamaLamaDingGone, of course!
Posted: Tue Apr 24, 2007 9:22 pm Post subject: |
| ideola wrote: | | FWIW, I ordered some ultra wide body rear quarter panels from AIR (American International Racing), and the quality is excellent. I believe they also have Carrera GT kits available. |
I'll second the AIR nomination. I picked up a set of CGT rear flares and a hood scoop from them a month or two ago and they are of decent quality according to my body shop. Have not begun to have them fitted but pleased with the service and quality.
Have never purchased from GT Racing, and probably never will based on others experiences. Sounds like they take no pride in their work and that just does not earn my $$$. |
Posted: Tue Apr 24, 2007 9:37 pm Post subject: |
Porschev: My front fender were made as a two piece part. There is an inner part that bolts to the firewall/door pillar and the outer panel. It is poosible the these weren't aligned properly before fiberglassing in place.
It's also possible if the panel was produced as a one piece part that the inner bolt holes wereen't made in the right spot.
Leadfoot _________________ 1981 ROW 924 Turbo -
Posted: Tue Apr 24, 2007 9:49 pm Post subject: |
Cool. Bargain too considering you dont get much change from 1K from porsche.
Depends on how many hours it takes to make fit well but Im sure youll have it looking good. Did U know the nose panel is spotted on? Like to see a pic when its done, or even before.
Fibreglass, resin, messy, sticky, itchy, yucky, smelly stuff. Dont want to make them but may buy one or even contribute to a group buy if other Aussies are interested.
Lets see how much demand there is. If it was viable to produce these commercially here do U think he`d be selling the moulds?
Come on any fibreglassers.......
Roger |
Posted: Tue Apr 24, 2007 9:53 pm Post subject: |
Leadfoot, any chance your fenders came out of these moulds?
Roger |
PORSCHEV
Posted: Tue Apr 24, 2007 10:55 pm Post subject: |
Well I guess that makes my decision on making parts...The market is shrinking fast!  _________________ 1976 924
Vince Ponz
Posted: Tue Apr 24, 2007 11:07 pm Post subject: |
For those of you who read my post regarding the rear flares will remember that I said that they did not fit properly. As a result I glued and then used screws to hold them on. You then have to use body filler to close the gap if you have any.
I would use 944 fenders for the front and not buy the FG ones. They fit well and all you have to worry about are the flares and the rocker panels.
The rocker panels are more trouble than the flares. You have to make them as Porsche never molded them and rather hand made them.
The GT flares are two piece units which are glued together. The part that you adhere to the body is a 2 in strip that may not fit too well. You will have to sand where needed and in some cases bent to fit the wheel well.
This should really hurt you. Yes, Mathilda you may want to cut the wheel wells up 3 in. or you will see them under the flares. Questions? Email me. _________________ "Never let them see you sweat"
77.5 924 modified track car
79 931 Euro stock
88 924S SE
87 911 Targa stock |
Posted: Tue Apr 24, 2007 11:13 pm Post subject: |
| RC wrote: | | Did U know the nose panel is spotted on? |
Yeah, I knew that... and am still wondering the best way to tackle it... might start another thread seeing if anyone has done this before...
69 911 |
924aussie
Joined: 02 Feb 2006 Posts: 1009 Location: Chinchilla Queensland Australia
Posted: Tue Apr 24, 2007 11:16 pm Post subject: |
| RC wrote: | Cool. Bargain too considering you dont get much change from 1K from porsche.
Roger |
Roger,
I have been talking to Jason who is selling the stuff on ebay and he is selling them because he has a porsche restoration business and wants to concentrate more on the 911 stuff.
I am willing to throw my $$$ in the ring as the last set of molds I looked at would have cost me around $3000
He also has this 911 stuff as well but not listed yet on Ebay
* 911 SC standard front and rear bars,
* 3.0 RSR front and rear bars,
* early 911S front bar,
* 3.0 RS front and rear bars
* 74 Carrera rear spoiler
* 74-89 Bonnet mould
Alan _________________ green 924 .. 1980 rego 924PSH
1998 Mopar Neon ... sick
2003 Challenger / Montery 4WD
1995 Hyundai Scoupe ... sold
1980 Fire truck Sold |
