get presure in fuel line
GRATIAN
PostPosted: Fri May 31, 2002 3:43 am    Post subject: Reply with quote
I clean up my injectors and put back on the engine.How can i fill the entire fuel line whith fuel to start the car.I know that fuel pump will start only when engine begin to rotate itself.
PostPosted: Fri May 31, 2002 12:09 pm    Post subject: Reply with quote
Just crank it until it starts, the system will fill itself very quickly.
gohim
PostPosted: Fri May 31, 2002 12:10 pm    Post subject: Reply with quote
The fuel pump will run when the key is in the "start" position, regardless of whether the engine is running or not.
When the key is in the "run" position, the fuel pump will only run when the engine is running.
Lizard
PostPosted: Sat Jun 01, 2002 11:37 pm    Post subject: Reply with quote
while the injector is out and you are spraying fuel light a smoke kaboom
GRATIAN
PostPosted: Sun Jun 02, 2002 6:37 pm    Post subject: Reply with quote
Hey Lizard I will make that if you come and take the injector in hand.
Lizard
PostPosted: Sun Jun 02, 2002 11:14 pm    Post subject: Reply with quote
ok can i point the injector at someone though, haha
[ This Message was edited by: Lizard on 2002-06-02 23:14 ]
