jesse wall
Posted: Sat Mar 24, 2007 6:24 am Post subject: 924 engine life? |
What is life of 924 engine? What are the most miles you know of without rebuild? What is life with rebuilds like rod bearings and rings ? Thanks just wondering as I keep hearing about engines being taken down and what great shape they are in, , curious Jesse _________________ jesse wall 'new driver' , 87 924s |
Posted: Sat Mar 24, 2007 6:56 am Post subject: |
I have read on these forums about 100k engines being disassembled and still showing cross-hatching marks in the bores, so it would seem the bottom end does very well. . .however I don't think you can get away with putting off headwork for much beyond that. _________________ Toofah King Bad
-nick
Posted: Sat Mar 24, 2007 7:14 am Post subject: |
^ sounds about right. The bottom end is for diesel abuse after all.
Headgaskets and valve guides / stem seals seem to need replacing north of 100k miles. Although, a lot of these cars have been abused with oil changes / overheating / etc. Leaky gaskets aren't uncommon on the oil pan, which is somewhat of a pain. _________________ 1980 931S
1991 964 C4 Cabriolet |
Andrew NZ
Posted: Sat Mar 24, 2007 11:40 am Post subject: |
Mine had done about 300,000km's before I finally seized it by over heating it in a rally. When it cooled down I topped up the oil and water and finished the rally (another 500km's) before I stripped it down and found the original honing marks in the block. I have most of the service records from new and it doesn't look like it had ever been rebuilt before!
These things are bullet proof! _________________ Andrew
1977 RX924 race car
12a bridgeport supercharged
www.race4-dcup.co.nz |
Andrew NZ
Posted: Sat Mar 24, 2007 11:44 am Post subject: |
I forgot to mention that they were standard size bearings and rings that came out........and standard size that went back in!!! _________________ Andrew
1977 RX924 race car
jesse wall
Posted: Sun Mar 25, 2007 8:59 am Post subject: |
wow!! What a neat thing to hear , thanks Jesse _________________ jesse wall 'new driver' , 87 924s |
StienbargerR
Posted: Mon Mar 26, 2007 2:40 am Post subject: |
yeah. my car has 180,000, and i runs ok, except i burns oil pretty bad.
ryan _________________ 1978 924 NA
-250lb lowering springs, Euro Pistons |
Raceboy
Posted: Mon Mar 26, 2007 3:07 am Post subject: |
My wifes '83 924 has 300 000+ kms on it and no rebuilds plus I turbocharged it few days ago.
Check Performance upgrades forum, there's topic about it. _________________ '83 924 2.6 16v Turbo, 470hp
'67 911 2.4S hotrod
'90 944 S2 Cabriolet
'78 924 Carrera GT replica
'84 928 S, sold
'91 944 S2, sold
'82 924S/931 "Gulf", sold
'84 924, turbocharged, sold.
Joined: 29 Jul 2001 Posts: 9071 Location: Royal Oak, MI, USA
Posted: Mon Mar 26, 2007 8:21 am Post subject: |
Yeah, I've found the 2-liters to be pretty robust down low, hard to kill except through neglect... though I've seen my share of those! _________________ Vaughan Scott
Joined: 04 Dec 2002 Posts: 767 Location: Blyth, Northumberland, UK
Posted: Mon Mar 26, 2007 8:08 pm Post subject: |
Well, the odometer on my 1978 hasn't worked since the late 1990's, but looking through the history folder and service receipts I know the car cleared 200k miles by the time I bought her. I had a piston ring break a couple of years in so I'd say it was around the 250k mark that we changed the engine to a reconditioned one. _________________ Mars Red '78 Euro 924 n/a
http://www.cardomain.com/id/5150_uk
Graphite? Grey Metallic '85 (late model) 944 2.5
There are two kinds of pedestrians: the quick and the dead. |
geddes66
Joined: 10 May 2003 Posts: 129 Location: Bakersfield CA
Posted: Wed Mar 28, 2007 2:19 pm Post subject: |
The crosshatching still shows on my sons '77, built Sep '76. The oil pressure is too high cold (7.5-8.5 bar) and too low hot (2.5) but replacing the filter with a short one and wrapping it in foil helped, (headers heating oil through filter via radiant heat?) an oil cooler is on the to do list.
I am running 5W-50 synthetic oil. I think the relief valve is stuck closed but haven't tried to remove it yet. _________________ The Porsche is now my son's, my car is cooler, slower but cooler. |
