Dynamite76
Joined: 13 Mar 2007 Posts: 21 Location: Richmond, Virginia
Posted: Sat Mar 17, 2007 5:29 pm Post subject: |
Hi bump, would like to use headlights in DE. I'm not throwing money away on high dollar stuff, as they will be completely ripped out when I find a tow |
muddy924
Joined: 12 Sep 2007 Posts: 9 Location: Shropshire. UK
Posted: Mon Sep 24, 2007 9:41 pm Post subject: |
Just joined. Hello all.
Ref these headlights. Has anyone done this conversion using a specific
manufacturers square unit (other than Narva unit that is) ?
Have just started checking out my local breakers here in the UK and found that some Jeeps come with square/oblong Hella units - but they all seem to suffer from reflector corrosion. Am trying to carry out mods on a limited budget hence trying to find existing units that can be adapted. |
endwrench
Joined: 07 Dec 2002 Posts: 1629 Location: Victor, Montana
Posted: Tue Sep 25, 2007 3:32 pm Post subject: |
Problem with most of the OE lights like the Jeep units is they are all glass with no real way to attach to. You would need to incorporate the bucket too and there isn't enough room. I used a cheap set of H4 units I found at a local parts store. They are sold as a replacement for sealed beam units.
These are the ones I used. Plastic backs with glass lenses. They have four screw bosses on the back to attach to. They don't come with bulbs.
http://www.amazon.com/Pilot-Performance-Lighting-WI-HL6A-Conversion/dp/B0006309WU
Todd |
muddy924
Posted: Sat Sep 29, 2007 10:01 am Post subject: |
Todd. They look great value for money and I can see what you mean about backing sections/bulk.
No sign on UK Google of this type of light unit (especially in RHD configuration) at any dealers. But at least I'm a small step forward knowing it is 6.5 x 4 inches.
Thanks for reply anyway. |
john h
Posted: Wed Oct 03, 2007 2:22 pm Post subject: |
Early model Toyota coronas (late 80's) and Subaru Leones used rectangular lights - I used these in my conversion in the early 90's with Hella inserts in the Toyota/subaru mounting frames _________________ Remember a Porsche is not just for Christmas,
xEcUtEr
Joined: 11 Apr 2008 Posts: 30 Location: Lisbon - Portugal
Posted: Sun Sep 14, 2008 10:32 am Post subject: |
Wouldn't call it easy. That's not the entire kit - but it will get you started I guess. However, even with a complete kit the job's a PITA (voice of experience, see my avatar).
69 911 |
xEcUtEr
Posted: Sun Sep 14, 2008 12:45 pm Post subject: |
pocketscience wrote: | Wouldn't call it easy. That's not the entire kit - but it will get you started I guess. However, even with a complete kit the job's a PITA (voice of experience, see my avatar).
G. |
it's easy to find a conversion kit... not doing the job! eheh
i don't know if i want to have all that painfull job eheheh
but it's a cool mod! _________________ 79' 924 2.0 @ Estoril Track |
Martijnus
Joined: 29 Dec 2006 Posts: 2020 Location: Netherlands
Posted: Sun Sep 28, 2008 11:50 am Post subject: |
xEcUtEr wrote: | pocketscience wrote: | Wouldn't call it easy. That's not the entire kit - but it will get you started I guess. However, even with a complete kit the job's a PITA (voice of experience, see my avatar).
G. |
but it's a cool mod! |
You have to learn that it is more satisfying to build this stuff yourself than to buy it.
If you can make this nicely yourself like macbdog, you can brag about your skills at the bar and laugh at the ricers who 'buy' stuff for too much money and find out that all their stuff fits like crap and doesn't look like what they expected. _________________ "Rule: Turbo's make torque, and torque makes fun." (C. Bell)
924 "50-jahre", 1981.
MSII/extra, LPG, ITB's, 5lug.
To be turbo'ed in a while.
CorsePerVita
Joined: 25 Jul 2008 Posts: 1994 Location: Redmond, Oregon
Posted: Tue May 15, 2012 3:26 pm Post subject: |
Just to update on this:
If you don't want to use the metal that was used you can use CF as well. I ended up opting to use pre-preg carbon fiber since it's already full of resin and is still somewhat stiff and pliable enough to make a template. The other nice thing is that you can cut it how you want it and mold it and then heat it up.
I'll post some pics when I'm finished with mine. I'm also trying to find a different way to mount the lense other than drilling into them and having the hardware visible on it, I would like to use 3M window weld or something to seal them. The lenses are still removable that way, and it can be resealed with the calking and it's black and looks nice and seals it from exterior stuff. I left a little overhang on the very rear of my lense so I can find a way to mount it with something on the back and 3M the rest.
Anyway... pics to come once I'm done.
BTW Thanks for the initial How To. The first time I tried making lenses it didn't go as I had planned. My issue was actually the material I laid them down on, the felt is necessary and you do definitely need enough sand to put pressure on the light to keep it from warping. Aside from that, it's pretty damn easy and took me a few minutes to cut them, a few more minutes in the oven and then just waiting for it to cool with the bag.
I prefer using fine weave than the larger weaves. I find it easier to work with and I think it looks better on auto parts.
Obviously this lense needs some fine trimming. But with a little trimming and a good fit with the new CF bucket I'm making it should turn out the way I want it. So far I'm very happy with the results
I'll get more pics later this week.
Pre-preg is pretty inexpensive to get ahold of, you won't have to mix your resin that way (if you're new to CF), you WILL need a LOT of heat though. You can totally do it with a heat gun but you have to get the stuff effing hot and you have to keep it hot for a while. That is probably the most time consuming part.
You'd have to find a good supplier local to you that has decent prices, you can look online too. But the stuff is light as a feather and easy to work with.
If you're more old fashioned you can opt to mix your own resin but for stuff like this where you're laying out simple curves and flat surfaces you could even mold it to a metal mold (like in page 1) heat it up till it's stiff where you want it, remove it from the metal and finish heating up the rest of it. _________________ - 1977 Porsche 924 2.0 N/A (Trackday Project)
- 1980 Porsche 931 (Daily)
- 1987 Lamborghini Jalpa
- 1999 Ducati 900SS |
edh
