Compression and Compressors
Goto page Previous  1, 2, 3, 4
Raceboy
PostPosted: Fri Feb 09, 2007 4:36 pm    Post subject: Reply with quote
Min, head-lifting results in the same symptoms as failed head-gasket.
When considering some serious boosting on a 2.5 NA engine, it's kinda obligatory to use 951 pistons+forged rods
'83 924 2.6 16v Turbo, 470hp
'67 911 2.4S hotrod
'90 944 S2 Cabriolet
'78 924 Carrera GT replica
'84 928 S, sold
'91 944 S2, sold
'82 924S/931 "Gulf", sold
'84 924, turbocharged, sold.
Min
PostPosted: Fri Feb 09, 2007 5:40 pm    Post subject: Reply with quote
ok, awesome, thanks for the info raceboy!
Min
special-tool
PostPosted: Fri Feb 09, 2007 8:26 pm    Post subject: Reply with quote
That's right.
It looks just like a burned gasket, but when you take it apart, you see no carbon traces and deformed (pushed out) fire rings.
The other telltale is that after you blow the expansion cap, the car is FINE!
You can drive it away. If you burn a gasket, you can't drive the car - well you can, but you will pull coolant into the cylinders at idle and wreck your rings. You will also leave a trail of smoke like Kimi Raikonnen behind you.
This video is my car making 500 plus at the wheels with head lift, watch what happens......
http://media.putfile.com/special-tools-543-hp-dyno
The car has stock 951 crank, rods and Mahle pistons in this video. You can see the bottom end isn't the problem when you use the 951 stuff.
My crank is exactly the same as the 86 NA, only rods and pistons are different.
951 566/485 HP/TQ at the wheels - pump gas
924S GTR conversion project
Honda 250R- PWK 35mm flat slide, 205 static, Boyesen, Wiseco, DG front/back, Uni, 14/42,
OutOfTheBox
PostPosted: Sat Feb 10, 2007 1:44 am    Post subject: Reply with quote
So how did you fix it, raceware headbolts ?
endwrench
PostPosted: Sat Feb 10, 2007 1:45 am    Post subject: Reply with quote
Min wrote:
endwrench wrote:
I have no doubt the latest MS system wil be more than sufficiant for your needs. I believe the others have some pretty nice features that may play an important role in an endurance race situation but will be of little use in a street application. Unless you plan to spend some serious $'s on dyno time and track sessions with frequent engine teardowns, I doubt you will ever be able to tell the difference.
What features?
Min
Biggest difference would be sequential injection and individual exaust temp comping.
Todd
Min
PostPosted: Sat Feb 10, 2007 2:52 am    Post subject: Reply with quote
I'm not sure how sequential injection helps at high rpm when the injectors are firing so fast that the port is just filled with fuel anyways. Maybe you know something I don't?
individual exhaust temp comping? .... whats comping? ..... like comparing?
Min
Glen931
PostPosted: Sat Feb 10, 2007 3:41 am    Post subject: Reply with quote
Special-tool Its nice to see someone running high boost on a 951. Iv been posting on clarks garage (front engine porsche forum) and everyone with a 951 keeps saying they cant take much boost. If you dont mind sharing what all you have done to the engine and drivetrain can you pm me with some info so we dont hijack this thread. thanks
Sequential injection allows you to adjust how much fuel is put into each intake runner which will allow you to tune each cylinders A/F ratio seperatly. Due to difference in flow of different intake runners the actual ammount of air that gets into each combustion chamber may differ slightly. basicly it lets you do more fine tuning when you are pushing the limits.
"Nitrous is like a hot chick with an STD, you know you want to hit it, but you are afraid of the consequences"
1980 porsche 931 beige
1987 Porsche 951 red, 51kmiles.. prefect cond.
1978 ford fairmont wagon 2.3 turbo engine
Min
PostPosted: Sat Feb 10, 2007 4:18 am    Post subject: Reply with quote
special-tool wrote:
That's right.
Awesome video, thanks for the good information.
Min
Min
PostPosted: Sat Feb 10, 2007 4:20 am    Post subject: Reply with quote
Sure, this is all quite obvious, however, how does all that help in endurance racing exactly? Which is what endwrench was saying, which I'm looking for a further explaination on.
Min
Min
PostPosted: Sat Feb 10, 2007 4:24 am    Post subject: Reply with quote
Also, http://www.sdsefi.com/techseq.htm
Min
endwrench
PostPosted: Sat Feb 10, 2007 5:27 am    Post subject: Reply with quote
Actually, I am relaying information from our old hot headed friend "Sequential". He may a bit of a a$$-O but I think he knows his stuff. He once mentioned the 931 as an example. As is known, the 924-931 have a heat problem on #4cyl. Not a problem unless you are trying to ring every last ounce of HP from the motor. With sequential you can add a little fuel or pull a little timing from just this one cyl while still creating max power on the other 3cyl without sacrafiecing reliability.
In a street situaition things are not as consistant day to day with differing weather, fuel quality, carbon buildup, etc.... so we have to run a little richer and pull more timing anyway just to be able to run every day without re-tuning. We make this sacrifice for drivability.
Todd
Min
PostPosted: Sat Feb 10, 2007 5:48 am    Post subject: Reply with quote
Ah ok, that makes sense. And I agree, Sequential knew his stuff.
Min
Raceboy
PostPosted: Sat Feb 10, 2007 9:45 pm    Post subject: Reply with quote
One more thing: sequential fuel injection allows to alter the injection angle which results in more efficient burning (=fuel economy) and maximum torque.
'67 911 2.4S hotrod
'84 928 S, sold
'91 944 S2, sold
Oysteinrb
PostPosted: Tue Feb 13, 2007 4:24 am    Post subject: Reply with quote
special-tool wrote:
That's right.
hmmm... so how do i know what bottom end my engine has got? where are the numbers and all that? how much will a 1983 944 bottom end take. umm. if anyone has any experience...
Page 4 of 4
