Posted: Sat Jan 20, 2007 11:18 am Post subject: garage heaters |
$39.99 from schucks auotparts for a tank mount heater
a dyna-glow tank top heater puts out
up to 15,000 put a fan behind it and presto it really
heats the garage up its been really cold out there.
 _________________ 1979 porsche 924 Na
Have u ever driven a turbo. |
Posted: Sat Jan 20, 2007 11:45 am Post subject: |
How much for the tank? _________________ Toofah King Bad
Posted: Sat Jan 20, 2007 12:35 pm Post subject: |
naa com-on thats off the barbie-que boy
I put a household fan behind it & it heats u
p the garage in no time _________________ 1979 porsche 924 Na
Posted: Sat Jan 20, 2007 12:48 pm Post subject: |
Bro, my barbie runs off these:
StienbargerR
Posted: Sat Jan 20, 2007 1:03 pm Post subject: |
My dad and I have always used a Kerosene heater to keep our garage warm. needless to say it goes outside when we deal with anything flammable. Heats the garage pretty quick 28 degrees to 80 degrees in about half an hour or less.
Ryan _________________ 1978 924 NA
-250lb lowering springs, Euro Pistons |
Why didn't I do this a couple weeks ago jeez
last week twas 27 degrees right now its 47 degrees
outside .. Ive had the heater on low for last 20 minutes
and its toasty out there in the garage.. I guess these heater use up a lot
of the oxygen in the air that's not a good thing .. ts gives off a peculiar smell too. Rastaman you gotta upgrade to a propane barbie you can
get a nice one for 150 bucks. Hey why you call yourself rastaman
dude. _________________ 1979 porsche 924 Na
Posted: Sat Jan 20, 2007 1:05 pm Post subject: |
Danger Will Robinson!
That unit will dump enough water into your garage to rust everything in sight.
Also it is a fire hazzard especially if you are painting....
BTDT, have been personally ON FIRE!! _________________ White 87 924S "Ghost"
Posted: Sat Jan 20, 2007 1:06 pm Post subject: |
| Paul wrote: | | BTDT, have been personally ON FIRE!! |
Now that's what I call the voice of experience. _________________ Toofah King Bad
Posted: Sat Jan 20, 2007 2:20 pm Post subject: |
It is it is.. kind of takes ya back to the day when that show was
the thing to watch I want to know more about the water thing
that's right no way would I paint with that thing on.. It
gives off a funky smell must be the propane I also know
these things take a lot of the oxygen maybe how do the bring
water and cause rust is it a moist heat .  _________________ 1979 porsche 924 Na
Posted: Sat Jan 20, 2007 2:22 pm Post subject: |
When propane is burned it produces water vapor. _________________ White 87 924S "Ghost"
Posted: Sat Jan 20, 2007 2:32 pm Post subject: |
gives off water vapor & carbon dioxide ..yea your right. _________________ 1979 porsche 924 Na
Posted: Sat Jan 20, 2007 2:37 pm Post subject: |
Yep its good for use in a well ventilated place, just don't tell Al Gore. _________________ White 87 924S "Ghost"
skemcin
Joined: 02 Sep 2003 Posts: 1284 Location: Plainfield, IL
Posted: Tue Jan 23, 2007 12:48 am Post subject: |
I'm actually half way through finishing my garage and this is the next item on my punch list.
I have Natural Gas plumbed into my house and my garage(2 car) is attached to laundry room. My laundry room (which I am remodeling now too) has gas piped there for the dryer. I'm going to pay someone to tap into that and run a line out to the garage (via the attic) where I am going to install a heater (undecided on appliance).
Given the responses to the propane idea, anyone have suggestions or pointers for this project?
(sorry if this is hijacking, I kind of see a relationship) _________________ 924.org (no time to complete)
9249206346 - 89k – new shifter bushings, belts, running well.
9249206347 - 8k – waiting its resurrection, no power at the fuel pump and fuse #7 blows w/power |
Posted: Tue Jan 23, 2007 2:47 am Post subject: |
Do a search on natural gas house heaters.. or a furnace guess you'd go that route get a furnace though might be on the spendy side rather than getting some kind of specialty heater to mount in the attic...
remodeling don't say it again I feel bad enough though haven't been told cause all I do is work on the car..... I still have to paint the cupboards,
then walls in our laundry room that is also plumbed for gas for the dryer
then replace all the counter tops in laundry room, kitchen, & bar ...then onto our bedroom where Ill replace carpet with wood floor then build
these really cool shelves I designed.. then install a flatt screen tv. I had a plumber come out and add a line from our laundry room to the hot tub a couple years back when we switched to a gas hot tub.. didn't cost to much to run the line about $150.00
including the inspection by an inspector. _________________ 1979 porsche 924 Na
