Speedo Cable
m8782538
PostPosted: Sat Dec 16, 2006 1:07 am    Post subject: Speedo Cable Reply with quote
Has anyone had to replace theirs? Mine has definately broken, i have the new one but don't know where the cable feeds through or which wheel it goes to. Can anyone help with this?
Thanks in advance.
Chrenan
PostPosted: Sat Dec 16, 2006 1:19 am    Post subject: Reply with quote
Front left wheel (when sitting in the car) is where it attaches to. Feeds through a hole in the fire wall behind the speedo.
The Fife
PostPosted: Sun Dec 17, 2006 4:32 pm    Post subject: Reply with quote
Is there a trick to routing the thing? I replaced my cable about 18 months ago and the gauge still bounces - moving the cable around does affect it but I can't solve the problem. Maybe the cable should be laid out from the bag it comes in for a day so it's straighter?
PostPosted: Sun Dec 17, 2006 5:05 pm    Post subject: Reply with quote
the bouncing speedo syndrome can also be as a result of worn or broken gears in the speedo.
dpw928
PostPosted: Mon Dec 18, 2006 12:11 am    Post subject: Reply with quote
The cable is actually a long spring and if dragging in the housing it can cause a bounce on the speedometer. I have also seen bent/pinched housings cause a bounce. Might try relubing first.
Dennis
81 931 5 sp
78 928 5 sp Silver
78 928 AT Euro Black
PostPosted: Mon Dec 18, 2006 4:12 am    Post subject: Reply with quote
If your not careful in preplacing like make sure you
seal the hub end up real good & also try to use the same
route as the original & lastly dont over bend the cable
Ive had 2 cables break in 5 yrs for these reasons.
Never had a bouncer though.
PostPosted: Fri Mar 02, 2007 6:18 am    Post subject: Reply with quote
What do you use for sealant?
PostPosted: Fri Mar 02, 2007 5:20 pm    Post subject: Reply with quote
A little dab of silicone gasket maker or whatever will do it - the blue stuff or the black, the bronze even.. Mine originally had some orange or red colored silicone on it.
For routing, if the original cable is still in place, cut the old cable at its' dashboard end about an inch or so from the end (just to remove the thicker parts, screw-on attachment, etc.). Securely tape that in-line to the wheel end of the new cable, then slowly pull the new cable into the engine compartment obviously by pulling the old cable in that direction.
PostPosted: Sat Mar 03, 2007 5:37 am    Post subject: Reply with quote
You um really have to have patience and squeeze your hand in tight
places to get the cable attached to the quage.
flames
PostPosted: Wed Aug 01, 2007 11:16 pm    Post subject: Reply with quote
Hey, my speedo is bouncing a fair bit, pulled the cable off the speedo and took it for a quick drive, the cable seems to have a bent at the end making the end of the cable come out at a strange direction, any idea's if ths would cause speedo bounce?
'78 924
Carrera? Body Kit
Bright Yellow
D Hook
PostPosted: Mon Aug 06, 2007 12:54 am    Post subject: Reply with quote
Yes, a bend in the cable will cause it to bounce. It could be the inner cable is dragging on the outer cable housing.
Is your speedo in the center of the bezel like the stock placement? I tried moving mine but didn't have the success that other have.
Did your year come with an oxygen sensor?
'80 924 n/a SOLD
flames
PostPosted: Mon Aug 06, 2007 9:07 am    Post subject: Reply with quote
Mine doesn't have a o2 sensor. got some oil and poured it down the cable, and this doesn't seem to have helped, I'm taking the car to licensing today, so will see of they pick it. Yep, my speedo is in the centre, what is the advantage of moving it? Are the speedo's interchangeable with anything?
'78 924
Carrera? Body Kit
Bright Yellow
968rz
PostPosted: Mon Aug 06, 2007 9:24 am    Post subject: Reply with quote
Some with the early dash's have moved the speedo so the tach is in the center ("like a real porsche"- not my words), I did this and it started to bounce so I moved it back. When I was an auto tech for Dodge we saw the speedos bounce on the shadows alot, we took the cable off the speedo- pulled out the inner cable and greased it up with get this "speedo cable lube", its just a light weight grease but not oil and it worked great.
Hope this helps
Rick
79 924 coupe Petrol Blue 3spd auto (wife's DD)
93 968 coupe Amazon Green 4spd Tip (my DD)
PostPosted: Mon Aug 06, 2007 9:26 am    Post subject: Reply with quote
911 owners claim that real Porsches have the tach in the middle. (They seem to forget about 914s)
steeny
PostPosted: Mon Aug 06, 2007 11:18 am    Post subject: Reply with quote
in RHD cars the speedo cable is not long enough to make the tach/speedo swap.
1978 924 N/A
she's gone.....
