tj924
Joined: 15 Jul 2004 Posts: 957 Location: Toowoomba, Queensland, Australia
Posted: Thu Dec 07, 2006 11:03 am Post subject: "putting" noise & gas escaping from #1 cylinde |
Had the car up on stands for a few weeks recently as my clutch cable snapped & I had to save my $ to get a new one ($137 inc. postage from Performance 9). Got the clutch cable installed (had to jack up the clutch fork to get it up enough to get the cable off & on the end, that was fun!!!).
Now when I start the car there is a definite "putting" sound from the #1 cylinder & I can feel gas escaping around the plug. I have removed, cleaned & reinstalled the plug, ensuring it is tight etc, but that made no difference. The noise & gas stops when I pull the #1 plug wire off the dizzy (car runs rough at that point, so is definitely firing on all 4 until I pull the #1 wire). It doesn't feel like gas escaping from around the exhaust manifold, but my guess at the moment is that it must be (ie needs a new exhaust manifold gasket). Any other suffestions?
My research suggests that the best way to change the manifold gasket is to pull the head with the intake & exhaust manifolds attached. Is that correct? Is this achievable for a newb? If so I would need a head gasket kit obviously, does the kit typically include all the other gaskets needed (exhaust & intake manifold gaskets, cam cover gasket, exhaust downpipe gasket etc)? _________________ TJ
Silver '82 924 NA 5-Speed Manual |
dpw928
Joined: 02 Nov 2002 Posts: 1860 Location: owasso, ok 74055
Posted: Thu Dec 07, 2006 12:28 pm Post subject: |
Try replacing the plug as they have been known to leak between the metal and ceramic insulator.
Dennis _________________ 81 931 5 sp
78 928 5 sp Silver
78 928 AT Euro Black |
crunchie 57
Joined: 18 Mar 2004 Posts: 117 Location: Brisbane Australia
Posted: Thu Dec 07, 2006 5:09 pm Post subject: |
| Quote: | Try replacing the plug as they have been known to leak between the metal and ceramic insulator.
or better still swap it over with another plug and see if the noise moves _________________ 78 924 N/A with 944 body kit (love this car)
79 924 NA - track car
81 924 Auto with 6V Buick |
Mike924
Posted: Thu Dec 07, 2006 6:10 pm Post subject: |
1) try the plug thing first, definitely
2) don't know for sure, but pulling the head to replace a manifold gasket seems a bit extreme to me
3) Are you running some kind of fancy clutch arrangement? A standard clutch cable here costs about £20 (AU$50)! _________________ 1985 Porsche 924 'Lux', Kalahari Beige (my ex)
Chrenan
Posted: Fri Dec 08, 2006 12:55 am Post subject: |
| Mike924 wrote: | | 3) Are you running some kind of fancy clutch arrangement? A standard clutch cable here costs about £20 (AU$50)! |
I was going to say the same thing! Is the clutch cable made of gold? _________________ 1987 951 - M193 Version for Japan |
Nobbi
Posted: Fri Dec 08, 2006 1:52 am Post subject: |
To replace the gaskets theire is no need to take the head off.Its not a lot off space but it is posssible.
That story with the plug is new to me, never heard about a problem like that.
Nobbi  |
tj924
Posted: Fri Dec 08, 2006 8:42 am Post subject: |
Got a new set of plugs yesterday ($15 for all 4 plugs, so I thought "why not"). Changed the #1 plug but it made no difference, so it must be the exhaust manifold gasket. I thought the general consensus here was that it's easier to pull the head with exhaust (& intake?) manifolds attached due to the tight space & often difficult/impossible to remove exhaust nuts/studs. Is that not the case?
Unfortunately the clutch cable isn't made of gold, Performance 9 is the only place I could find one locally with the only other option being to have one custom made for anywhere from $80 to $160 + postage. _________________ TJ
Posted: Fri Dec 08, 2006 10:41 am Post subject: |
Waite a minute do you know the price of a head gasket yet.
no you don't have to pull the head to do that stuff...you have to maybe remove the oil filter, and starter to get to the under side of the
exhaust plus the 5 lug down-pipe connection might not even have to be messed with that's a problem area where you'll brake bolts they rust
and wear away from the heat and stuff and over time become weak.
you'd be better off haven someone from the states get your parts
seems try the parts bin.  _________________ 1979 porsche 924 Na
Have u ever driven a turbo. |
tj924
Posted: Fri Dec 08, 2006 10:51 am Post subject: |
Checked PET & it would appear that all I need is 4 x gaskets "048 129 589 A" ($6 each), assuming I'm not missing any studs or nuts.
Any tips on replacing the Exhaust Manifold gasket from someone thats done it? Looks like I need to pull the spark plugs, remove the heat shield from the top of the car, then get under & remove the 8 x nuts holding the manifold to the head, remove & replace the 4 x gaskets & reassemble.
I recall Ozzie saying to lower the front crossmember to gain better access? _________________ TJ
dpw928
Posted: Fri Dec 08, 2006 11:32 am Post subject: |
Use the double nut technique to remove the exhaust studs. This will let you remove and replace the exhaust gakets with little or no movement of the manifold.
78 928 5 sp Silver
tj924
Posted: Fri Dec 08, 2006 12:01 pm Post subject: |
| dpw928 wrote: | | Use the double nut technique to remove the exhaust studs. |
Please explain further.
| dpw928 wrote: | | This will let you remove and replace the exhaust gakets with little or no movement of the manifold. |
So just slide the old gaskets out from between the head & the manifold, slide the new ones in & put the studs back in. _________________ TJ
dpw928
Posted: Fri Dec 08, 2006 12:18 pm Post subject: |
Put a second nut on the stud, tighten it to the other nut, then use a socket or end wrench to remove the studs. Once they are all removed, the manifold will separate from the head enough to change the gaskets.
78 928 5 sp Silver
tj924
Posted: Fri Dec 08, 2006 12:22 pm Post subject: |
| dpw928 wrote: | | Put a second nut on the stud, tighten it to the other nut, then use a socket or end wrench to remove the studs. |
Ah. I assume that the 2nd nut then stops the 1st nut from moving when trying to undo it, effectively turning the stud & nut combination into a bolt? _________________ TJ
Lizard
Posted: Fri Dec 08, 2006 12:25 pm Post subject: |
if you have never removed the exhaust before I would recommend that you replace all the studs going into the head along with the nuts, before installing coat everything with lots of never sieze. _________________ 3 928s, |
Ozzie
Posted: Fri Dec 08, 2006 1:21 pm Post subject: |
I didn't touch the crossmember when I done mine.
I replaced all the gaskets, all the studs and nuts with the head on the motor.
It was difficult and I removed the steering shaft (RHD), alternator and several heat shields. The engine pan is missing on my car but that would come off as well.
Dropped the exhaust off the manifold and actually managed to remove the manifold. I even retapped the holes for the studs.
However you should not have to drop the exhaust but just move the manifold to over enough to replace the gaskets.
The lower nuts are a real pain to get to tighten but it is do-able. _________________ Porsche 924 1984 (UK import) NA
Its AUTO and its BLACK
Montego Black on black/red
