Sorry, got another issue.
Goto page Previous  1, 2
Ozzie
PostPosted: Wed Nov 29, 2006 11:15 pm    Post subject: Reply with quote
exactly.
Its AUTO and its BLACK
Montego Black on black/red
Chrenan
PostPosted: Thu Nov 30, 2006 1:10 am    Post subject: Reply with quote
m8782538 wrote:
Plus in the second picture, there are a number of items that are not visable on my car, or are not there at all.
Ignore the second picture, that is the back of the engine, everything you need to set the cam/crank timing is at the front of the engine.
m8782538 wrote:
I have found the marking on the back of the top pulley but mine is a small circle
The small circle on the back is what you want to line up with the pointer on the cam cover. If it is the correct one, the small circle should be cast into the sprocket.
m8782538 wrote:
i also have a white mark on the front of the top pulley about a quarter the way around to the left from other backside marking.
Ignore this marking.
m8782538 wrote:
A Tad lost now, but to my understanding is as follows, get the two white marks on the bottom pulley and the two marks on the top pulley to match up, them attatch and tension the belt, all done.
Get the the top mark (on sprocket) and pointer (on cam cover) lined up, and the bottom mark (on pulley) and pointer (on oil pump) lined up, at the same time as having the correct tension on the belt (just able to twist 90 degrees with finger and thumb), and you are good to go.
m8782538
PostPosted: Thu Nov 30, 2006 2:07 am    Post subject: Reply with quote
Ok. Got it running again, doesn't quite feel 100% but it is running ok. I have however noticed that i am loosing coolant quite quickly, i have noticed a constant drip next to the alternator, behind the centre pulley for the Alternator belt. I have put the leak down to that, the oil seems fine the coolant has not oil being pumped into it. Any idea's what that is?
Ozzie
PostPosted: Thu Nov 30, 2006 8:10 am    Post subject: Reply with quote
You need a new water pump.
JakeFrame
PostPosted: Sat Dec 23, 2006 11:45 am    Post subject: better luck than I Reply with quote
Good to hear that you didnt have the same problem that I had. The head was blown out between cylinder 3 and 4. Had the same problem that you had with the running issue.
1976 924 Automatic- Body Only
1977 924 4 spd Red~For Sale~
1977 924 4 spd Yellow~For Sale~
1977 924 4 spd
1992 Mercedes 300e 4MATIC
emoore924
PostPosted: Fri Jan 05, 2007 3:37 am    Post subject: Reply with quote
Just for the record, you need not two but THREE things to align when you retension the belt...
1) Dot on the back of the cam pulley with the pointer on the valve cover
2) Crank pulley mark with pointer on front of engine
3) ROTOR POINTING TO #1 MARK ON RIM OF DIZZY
Without all 3 working together, cam, crank, dizzy, she no workee.
Page 2 of 2
