garyj19
Posted: Thu Oct 19, 2006 7:39 am Post subject: gross exhaust smell. |
everytime i drive my toofah, it smells terribly of exhaust. and then my clothes smell like it, etc and everything in the car does too.
is this bad? well, yes its bad but what should i do? anyone else have this issue?
am i going to die soon from carbon minoxide? _________________ early 77 924 na |
Ozzie
Posted: Thu Oct 19, 2006 7:50 am Post subject: |
Must be something with the design.
Check all the rear seals for the hatch, taillights and drains.
I'm assuming the exhaust is OK? _________________ Porsche 924 1984 (UK import) NA
Its AUTO and its BLACK
Montego Black on black/red
Posted: Thu Oct 19, 2006 8:01 am Post subject: Re: gross exhaust smell. |
| garyj19 wrote: | everytime i drive my toofah, it smells terribly of exhaust. and then my clothes smell like it, etc and everything in the car does too.
am i going to die soon from carbon minoxide? |
Check Timstars posts, this has been covered in great detail. _________________ White 87 924S "Ghost"
Ozzie
Posted: Thu Oct 19, 2006 8:06 am Post subject: |
His hatch didn't fit properly and after hundreds of posts (it felt like it) still never aligned it. _________________ Porsche 924 1984 (UK import) NA
timstar92404
Joined: 22 Sep 2004 Posts: 2075 Location: richmond BC
Posted: Thu Oct 19, 2006 12:03 pm Post subject: |
it wasn't an allignment thing with my hatch, I'm pretty sure the metal on the hatch was warped and was not closing airtight.
the hatch on my 924 is separating from the glass in one spot and I got a tiny bit of water dripping in when I washed it so that could cause a problem aswell.
also I noticed when I washed my 944 that the tail-lights filled up with a lot of water and it was because the caulking seal was leaking. I had to use new caulk and now they don't leak water.
use a garden hose to spray all around the hatch and if you get water into the car (other than a overflowing drain tube) then you should probably assume fumes are getting in.
the problem is that it is not easy to get the hatch to seal all around, sometimes you may just need a new hatch seal but it could be a bad hatch frame (replace the hatch) or it's possilbe it might need adjustment (if it's not cllosing tight enough). _________________ 78 924 sold.
85.5 944 |
timstar92404
Posted: Thu Oct 19, 2006 12:06 pm Post subject: |
also I did a search on rennlist and I found that there a a few others with 944s with the same problem and they can't figure it out.
if I have this problem with my 944 I'm going to drive it into a lake and buy a Yugo. _________________ 78 924 sold.
85.5 944 |
JB 924
Joined: 03 Apr 2006 Posts: 606 Location: Hessen, Germany
Posted: Thu Oct 19, 2006 12:07 pm Post subject: |
| The hatch seal on my car went all around the lip, but it stopped around 2-3 inches to the left and to the right of the key lock. I could see into the car through there. What piece is supposed to be there? |
Posted: Thu Oct 19, 2006 12:11 pm Post subject: |
Your hatch seal has shrunk!!
I always keep a few old ones around the shop so that when I see that problem, I just cut a piece to the correct length and glue it in.
Too bad you're in Canada since I usually charge one cold beer for anyone who drops by for that repair.... _________________ White 87 924S "Ghost"
JB 924
Posted: Thu Oct 19, 2006 12:44 pm Post subject: |
You kiddin' or serious? That's like 6 inches of shrinkage.  |
Slam
Posted: Thu Oct 19, 2006 1:11 pm Post subject: |
Bumper to Bumper sells generic seals that work perfectly for this application. They actually seal better than factory - there's more meat on 'em. My wife picked up enough to do her hatch and deliberatelt installed it so the part number was right side up, lower left corner, bless her, in case she needed to buy more! I'll get the number in daylight. Very, very cheap compared to factory seal. _________________ '84 944 - kid blew motor
'80 924 - gone
'78 924 - gone
JB 924
Posted: Thu Oct 19, 2006 1:23 pm Post subject: |
Thanks Slam!
I just checked on Pelican Parts, thinking that the dealership would charge too much. They want $107! I think they're a little overpriced anyway, though. But still. Thanks. |
D Hook
Ozzie
Posted: Thu Oct 19, 2006 7:32 pm Post subject: |
How do you make a Yugo go faster?
A towtruck.
What do you call the shock absorbers inside a Yugo?
Passengers.
Two guys in a Yugo were arrested last night in Oakland following a push-by shooting incident.
The new Yugo has an air bag. When you sense an impending accident, start pumping real fast.
A friend went to a dealer the other day and said, "I'd like a gas cap for my Yugo." The dealer replied, "Okay. Sounds like a fair trade."
I have also said for years that the car is named because "Yugo, but it doesn't".
How can you get a Yugo to do 60 miles an hour?
Push it over a cliff. _________________ Porsche 924 1984 (UK import) NA
Nobbi
Posted: Fri Oct 20, 2006 1:52 am Post subject: |
I have the same problem since years......
Now i`ve lost all my hair,thanks to the lead-fuel i smoked in nearly 18 years of driving my 924.
I tried new seals, put ducktape around the whole outer hatch, used acryl to seal the taillights,put all round shaped plastik parts into the body,replaced all seals at the exhaust system, nothing worked out.
The only thing that i didnt tried was to seal the frame to the glass itself.
Do that next,sounds like a possible solution.
Good that it only happens with lowered side window.It s not to hot over here.
Up-in -smoke !  |
924guy
Posted: Fri Oct 20, 2006 2:06 am Post subject: |
| Quote: | | also I noticed when I washed my 944 that the tail-lights filled up with a lot of water and it was because the caulking seal was leaking. I had to use new caulk and now they don't leak water. |
thats not water, thats blinker fluid....  _________________ Eric
78 924
82 931 SE "smokey"
99' VehiCross
Y2K Honda Insight
Performance by Pasha |
