Where's Timstar944??
Goto page Previous  1, 2, 3, 4, 5  Next
timstar92404
PostPosted: Sat Jun 17, 2006 3:39 am    Post subject: Reply with quote
well if I get the TDC correct (which is going to scare me) then it should be okay. 90 degree method would only be temporary,if i do it myself I would get the tensioned checked by a shop.
I wouldn't mind if someone who knows what they are doing to come help me. The first time I changed the timing belt on my924 I had the cam completely wrong and it wouldn't start then I fixed that and it would start adn the timing belt was running at the edge of the camshaft like it was slowly coming off the edge.
if it's looks impossible for me to do I'll just have a shop do it. No point in doing preventative maintenance yourself that kills the engine faster.
78 924 sold.
85.5 944
Stu2j
PostPosted: Sat Jun 17, 2006 4:27 am    Post subject: Reply with quote
What one man can do... so can another....
I BELIEVE IN YOU TIM!!!!!!!!!!!!!!!!!
-Stu
924 owner since 1988
924S owner since 2002
Click here to view them:
jamez
PostPosted: Sat Jun 17, 2006 5:01 am    Post subject: Reply with quote
there is a free 2.5ltr '83 944 engine on the V8 message board. said it runs good... check it out. would be good for parts/backup anyway.. http://www.560sec.com/bulletinboard/viewtopic.php?t=1320
Porscheaddiction
PostPosted: Sat Jun 17, 2006 5:08 am    Post subject: Reply with quote
If you do that with a 944 you have just created yourself a top end rebuild most valves will be bent.
good luck tho.
Chris.
1981 924 NA (Restoring mode)
1984 928S (Enjoying the driving season)
skemcin
PostPosted: Sat Jun 17, 2006 6:04 am    Post subject: Reply with quote
timstar92404 wrote:
... 90 degree method would only be temporary ...
I'd bet it would be VERY temporary.
(err but what I am I doing repsonding)
(don't click "submit")
(back away skemcin)
(but he might listen this time)
924.org (no time to complete)
9249206346 - 89k – new shifter bushings, belts, running well.
9249206347 - 8k – waiting its resurrection, no power at the fuel pump and fuse #7 blows w/power
timstar92404
PostPosted: Sat Jun 17, 2006 6:10 am    Post subject: Reply with quote
haha, that's not my idea. Go ask Clark on Clarks garage he says using the cricket or even finger method of tensioning is fine as long as you recheck the tension after the 2000 mile stretch and periodically check the belts (make sure it's not humming).
do I feel confident in driving a hand tensioned belt for a long time, NO.
but it's not like a hand tensioned belt is going to snap or come off right away unless you make it really lose or make it crazy tight, it's just if you leave it like that it won't last as long.
most people I assume hand tension their 931 here and those are interference motors.
78 924 sold.
85.5 944
PORSCHEV
PostPosted: Sat Jun 17, 2006 6:44 am    Post subject: Reply with quote
Tim...the PO said that the belts had been serviced...why can't you just pull off the timimg belt cover and inspect the belt and water pump...drive the car for the summer and have the belt done before you go off to school agian. The truth is...you can find an entire motor for what your looking to spend for a front end service.
1978-#53 "D" track racer.
PostPosted: Sat Jun 17, 2006 9:18 am    Post subject: Reply with quote
Some pictures of the belts:
http://im1.shutterfly.com/procserv/47b4df25b3127cce9cba47d81b2600000016108AZuGrlozZtE
http://im1.shutterfly.com/procserv/47b4df25b3127cce9cba47db9a1500000016108AZuGrlozZtE
http://im1.shutterfly.com/procserv/47b6d837b3127cce8a7eaddf6b1400000016108AZuGrlozZtE
timstar92404
PostPosted: Sat Jun 17, 2006 9:27 am    Post subject: Reply with quote
he said that the belts and rollers were done but said nothing about the water pump and said he'll try to find the receipt I asked him again to find the receipt.
I'm probably getting the car maybe tom or latest tuesday or wednesday.
I guess I can remove the front cover look at the belt and see if it is new..... hard to tell but I guess if the writting on the belt looks new and isn't faded the belt must be fairly new right?
hard to tell if the rollers are new they could just look really clean. But even if the timing belt and rollers are new and the water pump is 10 years old that's not going to last very long, I don't want a leaking or seized water pump when I'm back in school.
I'm guessing with 240,000 kms the water pump must have been replaced at some time or couple of times by now.
yeah with 1800-2000 timing belt service I'm pretty sure you can find a good used motor, I just saw a crashed 944 with running motor for 800 on craiglist. Now replacing a motor would be impossible to do by myself.
78 924 sold.
85.5 944
PORSCHEV
PostPosted: Sat Jun 17, 2006 9:48 am    Post subject: Reply with quote
Not impossible at all...I have changed lots alone!
D Hook
PostPosted: Sat Jun 17, 2006 10:18 am    Post subject: Reply with quote
Suitable for framing:
'80 924 n/a SOLD
Chrenan
PostPosted: Sat Jun 17, 2006 10:20 am    Post subject: Reply with quote
Yikes. Plain vanilla 924 is comlicated enough for me thanks.
JB 924
PostPosted: Sat Jun 17, 2006 11:49 am    Post subject: Reply with quote
After getting my clutch out and dropping the tranny myself, nothing seems impossible anymore...
gohim
PostPosted: Sat Jun 17, 2006 2:09 pm    Post subject: Reply with quote
Chernan,
If you think that looks complicated, you should see the engine with both belts install. Right now you're just looking at the timing belt. The balance shaft belts in located immediately in front of the timing belt.
gohim
PostPosted: Sat Jun 17, 2006 2:18 pm    Post subject: Reply with quote
Good Used Engines.
The problem with buying a good used engine is the fact that it will not come with a history. I can buy what are supposed to be good used running engines all day, priced from about $400 up. The problem is the fact that a used engine needs a full service, which is much easier to do while the engine is out of the car, AND how about the clutch? Anyone installing an engine would be a fool not to replace the used clutch while the engine is out. There goes another $600 for parts.
So a good running $500 engine will need $1200-$1400 in service parts (front of engine service, clutch set, and how about a oil cooler reseal while everything is out of the way)?
And that does not include the cost of the labor to pull the old engine and install the new one, if you are not doing the labor yourself.
So a an engine replacement with a $500 engine ends up being at least $3000, and you still don't know how good the innards of that $500 engine are, even if it looks good, and you saw it run before it was pulled.
Page 2 of 5
