Battery connector corrosion
Porscheaddiction
PostPosted: Sun Jun 04, 2006 5:14 am    Post subject: Battery connector corrosion Reply with quote
Not sure if this happens to everyone or not but it seems about every 2 yrs or so I have to replace the battery connectors.Does everyone seem to have to do this?. Now I am kind of curious if there is some sort of dielectric grease to put on the battery terminals/connectors to help with the corrosion of the connection at the battery?
Thanks
Chris.
1981 924 NA (Restoring mode)
1984 928S (Enjoying the driving season)
Last edited by Porscheaddiction on Sun Jun 04, 2006 5:25 am; edited 1 time in total
PostPosted: Sun Jun 04, 2006 5:16 am    Post subject: Reply with quote
you could use vasoline instead of di-electric grease, alot cheaper.
3 928s,
Porscheaddiction
PostPosted: Sun Jun 04, 2006 5:24 am    Post subject: Reply with quote
Ok I did think of trying that but I have always thought that Vaseline would not allow the power to transfer properly from the battery to the conector.
Thanks
Chris.
PostPosted: Sun Jun 04, 2006 5:46 am    Post subject: Reply with quote
"dielectric" actually means non-conductive. You don't even have to take my word for it - it should be in any dictionary. Vaseline should work just as well as dielectric grease on battery posts. The main difference between the two is that Vaseline is petroleum-based while dielectric grease is normally silicone-based. Silicone is better for rubber and plastic parts (connectors) and haqs higher heat endurance.
There is such a thing as conductive grease. It's black in color and very expensive - best place to find it would be a well stocked electrical supply place where professional electricians go. It's mainly meant for use on aluminum wire connections in homes/buildings.
Porscheaddiction
PostPosted: Sun Jun 04, 2006 5:49 am    Post subject: Reply with quote
ok then so can vaseline be used on battery posts and battery connectors to prevent corrosion but still allow excellent power transfer from batt to conector?
Chris.
PostPosted: Sun Jun 04, 2006 6:13 am    Post subject: Reply with quote
Yes.
-and use dielectric grease specifically on multipin connectors to protect from corrosion and prevent current from traveling through the grease from one pin to another.
Porscheaddiction
PostPosted: Sun Jun 04, 2006 7:00 am    Post subject: Reply with quote
Thank you very much for the information guys
its appreciated
Chris.
