cbush35
Posted: Thu Jun 01, 2006 12:12 am Post subject: Please help with Timing Belt ? |
| I have 82 924, changed out timing belt, did not turn over motor before removing, now car will not start, any ideas???????????? |
Ozzie
Posted: Thu Jun 01, 2006 8:03 am Post subject: |
You are in the wrong section - try general discussions.
This section is for people to put their repair details in.
You need to line up the flywheel mark, the cam mark (the rear one) and the distributor rotor should be pointing at no.1 cylinder lead. _________________ Porsche 924 1984 (UK import) NA
Its AUTO and its BLACK
Montego Black on black/red
Mike924
Posted: Thu Jun 01, 2006 5:23 pm Post subject: |
Most likely you're one notch out with the timing belt. Line everything up like Ozzie said then try again. (assuming you've checked for all the non-related silly little things that can prevent a car from starting...) _________________ 1985 Porsche 924 'Lux', Kalahari Beige (my ex)
timstar92404
Joined: 22 Sep 2004 Posts: 2075 Location: richmond BC
Posted: Thu Jun 01, 2006 5:44 pm Post subject: |
the camshaft mark, a stamped circle between two of the teeth needs to be alligned with the pointer of the camshaft cover. Then the cut in notch on the vbelt pulley on the cranshaft needs to be alligned with the pointer on the oil pump (triangle pointer). When you tighten the belt you have to make sure the marks do not move. Most likely why it won't start. That's what happened to me and I freaked out. _________________ 78 924 sold.
85.5 944 |
