Sharp turns
924er
PostPosted: Thu May 25, 2006 9:04 am    Post subject: Sharp turns Reply with quote
not that i make sharp turns everyday but when im turn going really fast, just normal, my red oil light indicator comes on for about 5 seconds. is that something to worry about??
80' Porsche 924 NA - Slower then a S L O W
86' Porsche 951- New toy
View user's profile Send private message Visit poster's website AIM Address MSN Messenger
doomer77
PostPosted: Thu May 25, 2006 9:22 am    Post subject: Reply with quote
its totally normal, proberly a worn oil pump not being able to keep up. you dont need to worry about the oil light until it stays lit constantly
Why drink and drive when you can smoke and fly?
Carpe diem. and if that doesnt work; get drunk!
1980 924 n/a - engine swap begun
1989 Volvo 480ES
Meneer aard
PostPosted: Thu May 25, 2006 9:43 am    Post subject: Reply with quote
Check also your oil level just in case
Porsche 924 Euro 1977
924er
PostPosted: Thu May 25, 2006 12:07 pm    Post subject: Reply with quote
yea my oil level is fine so i guess its fine, oh well just making sure. because the last time i saw a light go up like that is when my sister's engine blew
WhoDak
PostPosted: Thu May 25, 2006 12:33 pm    Post subject: Reply with quote
When you take sharp turns all the oil rushes against one side of the engine so it isn't being recirculated from the bottom at full capacity...you lose pressure slightly, the light comes on. Car levels out, oil is being drawn from a mostly level body of oil, pressure normal, light off.
Kind of the same thing with your gas tank, ever take a hard right hand turn with less than 1/3rd of a tank and see the needle run into the left side of the gauge and the light come on?
Mike
'82 924 N/A
'91 Toyota Pickup SR5 4x4 Xtra cab
N-Dub
PostPosted: Thu May 25, 2006 12:50 pm    Post subject: Reply with quote
When the light comes on in the turns I tell people that it is my g meter and I am pulling my max skidpad abilities.
'79 924 now Totaled! Carrera GT bodywork for sale!
'87 951
Lizard
PostPosted: Thu May 25, 2006 2:04 pm    Post subject: Reply with quote
the light should not actually come on during any hard cornering, if it does something is wrong, if you are accelerating through a hard turn and loose oil pressure that is what will cause a rod bearing to spin, there goes the rod, and the crank will have to at the very least need to be machined
3 928s,
PostPosted: Thu May 25, 2006 10:09 pm    Post subject: Reply with quote
That shouldn't happen on the street, IMO.
What does your oil pressure gauge say at the time? If it's also reading low (1 bar or less), I'd be concerned about actually having an oil pressure problem.
But if it's not (the oil light should come on only when pressure is below 1 bar), I'd suspect a wiring problem - could easily be an exposed sender wire grounding out. Check your wiring.
John Brown
PostPosted: Thu May 25, 2006 10:32 pm    Post subject: Reply with quote
Ditto. What Vaughan said.
It's not normal and you should fix it.
John
80 931 - #931 44Cup
99 Escalade - tows track cars
gone but not forgotten: original 924.org car - 82
N-Dub
PostPosted: Thu May 25, 2006 10:41 pm    Post subject: Reply with quote
The oil bar doesn't really change. It is just a jerk of the wheel and the oil sloshes to one side then levels out. Having experienced I don't think you should worry about it too much.
'87 951
924er
PostPosted: Fri May 26, 2006 1:39 pm    Post subject: Reply with quote
edit
924er
PostPosted: Fri May 26, 2006 1:42 pm    Post subject: Reply with quote
awww, are you still mad about the street racing video????
if ya...
PISS OFF MY THREAD unlike the rest of these nice helpful people on this forum.
PostPosted: Fri May 26, 2006 1:43 pm    Post subject: Reply with quote
I think you mis-understood him..
Tigger937
PostPosted: Fri May 26, 2006 2:44 pm    Post subject: Re: Sharp turns Reply with quote
If this is an actual momentary oil pressure loss, a Porsche Master Technician once told me that keeping the oil level approx. 1/4" above the full mark when autocrossing, tracking, etc. will prevent this from happening. Can lead to excessive cam wear among other things mentioned previously.
1981 931 (Concours)
1982 931 (Daily Driver)
"Think outside the box"
924er
PostPosted: Sat May 27, 2006 11:05 am    Post subject: Reply with quote
yea well i experienced this after i got an oil change so thats prolly why
