New '81 931 owner- Huzzah!
phoenix02
PostPosted: Sun Apr 16, 2006 7:51 am    Post subject: New '81 931 owner- Huzzah! Reply with quote
Hello all,
I just won an '81 931 (ebay item number 4630059093 if you want to lookit up). I'm going next weekend to check it out and do some work on it- the seller is going to help me get it back in one piece to make the 100 mile trek home. I was looking for a daily driver car that would be fun, not all too terribly hard to work on, and perhaps when more money comes along, to fix up nicely. I have a few questions-
1-Do you think I got a good deal? The seller is also knocking it down to $550 final price to pay for the smog test. From what I've seen, it looks like a good deal.
2-The engine was rebuilt with 8.5:1 compression, a 1 bar spring installed, and there's a front mount IC included to be installed. on California premium (91 octane) gas, do you think this combo would cause detonation? I need a car reliable enough to not have to rebuild the engine every year or replace the head gasket everytime I do an oil change.
3-Do I need to/ should I put in a water/methanol injection system to negate detonation? Do any of you know if it is california smog legal? I was thinking about designing my own system with the tank hidden in the spare compartment or trunk area and piped up to the engine, so it's pretty much totally hidden. If I do install one, does the injector have to be after the throttle body in the intake to prevent rusting the TB butterfly, or is it okay to be between the turbo and the TB? I've never had a turbo car, so any ideas would be greatly appreciated.
4-Would a K&N CAI kit make any difference over the stock airbox?
5-I'm 6'2" and 300 lbs- do you think I'll have much of a problem in the car? I'v eheard they're roomier than they look. Can anybody give me a comparison interior size? Geo Metro small, Ford Probe medium, Crown Vic large...
I've spent about 15 hours since I bought the car looking at the boards on this website, but have yet to find definitive answers to all my questions.
Thanks alot to anybody that can help me out!
-Michael
PostPosted: Sun Apr 16, 2006 8:10 am    Post subject: Reply with quote
Welcome to the board and congrats on the 931 (924 turbo).
To best help you, please add at least the state you are from in your profile. I assume it's California....
A 1 bar spring can cause engine damage (think BOOM) so care must be taken. The IC will help but they are a PITA to install.
I suspect you will have a difficult time getting this car to pass emissions, but we are here to help.
Based on the description of the car, you can expect to spend several thousand dollars to bring it back. The first concern is the timing belt since these cars are interference. Even if the seller says it's new, take a look at it before starting the car.
PostPosted: Sun Apr 16, 2006 9:10 am    Post subject: Reply with quote
They're actually one of the roomier sportscars as far as legroom is concerned. 6'4", 6'6" drivers fit nicely. I recall one guy from BC Canada mentioning he's 6'8" and fits, but his left knee is right next to the steering wheel.
I'm 6'0" and just under 220 lbs. and just got a suprise when I went to adjust my parking brake the other day... I took the seat out and found I only needed to remove 3 bolts - the other one (front-right) was already torn out along with a 1.5"x2" piece of sheet metal. (The front-left one was torn out and already repaired before I got the car approx 14 years ago. -I suspect a rear-end accident had something to do with that.) Anyway- the sheet metal is very thin - I measured it at 19 gauge (1mm or 1/16" thick). Along with that, I also found some cracked and sagging sheet metal under the car diagonally opposite the bolt that I just found torn out (rear-left). So the front-right had lifted and torn out, and that led to the rear-left being pushed down more, BUT (that's my big but) there were other contributing factors.. Being a bit on the taller than average side, I drive with my seat pushed back pretty far (this shifts my weight more over the seats' rear mounts), in addition, I keep the seat reclined more than the average driver (this shifts still more weight even further back), and like I said, I'm just under 220lbs., so several factors are adding up there and the result is lots of lifting stress on the seats' front bolts and lots of down force on the rear bolts. -And when the front-right tore out, the downforce on the rear-left increased enough to push down and tear the skinny 19 gauge sheet metal in two spots right there under the car.
Long story short - check the seat-to-floor mounting bolts, check for cracking sheet metal near them and check the bottom of the car below the seatback for sagging and cracks. -And keep that 19 gauge sheet metal in mind before developing any habits like falling into the seat on entry every time.
phoenix02
PostPosted: Sun Apr 16, 2006 10:57 am    Post subject: Reply with quote
Okay, I'll check out the sheet metal- I just got some cheap Neoprene seat covers, so that'll make 'em easier for me to slide in and out- less plopping down.
As far as the timing belt- I thought the 2.0 was non interference.- are you thinking about the 2.5 from the 944-up, or am I mistaken/ did they change the engine sometime in the production run?
That couple thousand estimate- is that mechanical, or with new interior, paint, etc? If th eengine was just rebuilt and a new clutch installed, I can't see how it could be a couple grand just for mechanicals to get it back on the road... then again, I've never owned a porsche.
Why wouldn't it pass emissions? Are an IC and water/meth injection not smog legal? The reason I even got another car was because my Jag has a '70 motor in a '76 car, so the smog police are giving me all kinds of crap. If something improves emissions/ combustion/ relability (IC, CAI, water injection, etc) it really bugs me that we can't have in Cali. It's like the gun laws- no 50 cal BMG guns here. I can understand not having automatic weapons, but why not a gun that is pretty much good for only target shooting? Is someone going to rob a bank with a gun that knocks you on the butt with each shot and takes 2 seconds to operate the bolt?
I'm sorry for a totally unrelated rant, but it's just an example of why Cali kinda sucks in some respects. I'm hoping to expatriate to another country, like Tennessee or somewhere else in the south some day. only problem is with the lack of un rusted out old cars.
'81 Porsche 931
'76 Jaguar XJ-12 w/ Chevy 350 from a '70 'Vette
'84 GMC Suburban C-2500
Save your sanity- kick a puppy.
Save your puppy- kick your mother-in-law.
PostPosted: Sun Apr 16, 2006 11:23 am    Post subject: Reply with quote
The 2.0L 924NA is non-interference, but the 2.0L 931(924T) is interference.
PostPosted: Sun Apr 16, 2006 11:46 am    Post subject: Reply with quote
You bought the car for the price of the new tires or for about what some have paid to have the turbo rebuilt so you are off to a good start!
The car has the Audi transaxle which is good since parts are available and there's lots of good used ones. A new clutch is a real bonus (parts are about $500).
The ignition system is unique to 81 and 82 931s so certain parts are becoming difficult to find.
A good paint job will cost thousands, a decent interior can be sourced from a younger 944.
The fuel injection system is CIS which hates to be left sitting around. Parts are expensive. It uses 2 fuel pumps, a WUR, a fuel Dizzy, an AAV, etc. Each of these are hundreds of dollars each.
The brake and clutch hydralic parts may also have suffered from not being used. Not cheap either.
Got to wonder why the guy is selling it for 1/4 of the cost of the parts he's put into it....
Hopefully it will start and run and pass emissions, if not you know where we are. We'll do everything we can to help you save a 931!
phoenix02
PostPosted: Sun Apr 16, 2006 5:23 pm    Post subject: Reply with quote
Thanks alot- it's great to have such a comunity atmosphere here.
Right now, my budget was my tax return- all of $1300- for a vehicle. So far, I have $580 gone for the car, seat covers and a Haynes manual. That leaves me with $720 for the registration, smog, etc. Basically, e-bay and junk yards shall become a friend to me all over again. Does anyone happen to have any of the porsche factory 931 manuals on CD they'd be willing to make a copy of for me, or know of anywhere I could pick them up cheap?
'81 Porsche 931
gohim
PostPosted: Sun Apr 16, 2006 6:28 pm    Post subject: Reply with quote
Welcome, and good luck with your new project. The least expensive places to buy parts are the Pomona Porsche/Corvette Swapmeet at the Pomona Fairgrounds, the Internet, aftermarket parts Sellers from magazine ads, and discounting Authorized Porsche Dealers, not necessarily in that order.
If the engine was rebuilt properly, and the turbo is in good condition, then getting the car to smog should not be a huge problem, as long as the fuel system is not screwed up.
I looked at the owner's eBay ad, and if you looked at the photos carefully before you bid on it, you know that the body needs work, and not just paint.
The engine was rated 156 by Porsche in original form, not 140 as the Seller advertised. The 8.5cr pistoned Euro 931 engines were rated 177. You are going to need to buy a good grade of premium gas all the time.
If the fuel system or ignition system has been hacked, then the $700 remaining in your budget isn't even going to be a down payment.
Don't waste (oops spend) any more money (on worthless cosmetic stuff, until you get the car home and running) until you see the car, and get an idea of what it will need to get it running properly. You are going to have to pay for the DMV transfer, sales tax, registration, smog check, and that's already going to cost you $200 or more.
You will need to buy the Factory Workshop Manual (four volumes) for the 924 AND the 931 (924T) single volume. I got my brand-new (at the time) 931 manual from the Pomona swapmeet for $25. The 924 Workshop Manual that I have also came from the Pomona Swapmeet ($75). Porsche sells the Service manuals on paper, and on microfiche. You can find copies being sold on eBay on CD or DVD. These are all unauthorized, illegal copies scanned and stored in pdf format.
PostPosted: Mon Apr 17, 2006 12:48 am    Post subject: Reply with quote
A few pics to go with my previous post -
Here's the cracked sagging sheet metal below the rear-left seat mount -
http://pg.photos.yahoo.com/ph/smoothies931pics/detail?.dir=/a174&.dnm=fef1.jpg&.src=ph
this shows where to look for it -
http://pg.photos.yahoo.com/ph/smoothies931pics/detail?.dir=/a174&.dnm=66d0.jpg&.src=ph
Here's the torn-out front-right mount -
http://pg.photos.yahoo.com/ph/smoothies931pics/detail?.dir=/a174&.dnm=e59b.jpg&.src=ph
-and repairs viewed from below -
http://pg.photos.yahoo.com/ph/smoothies931pics/detail?.dir=/a174&.dnm=22c4.jpg&.src=ph (some countries require plates of a specific minimum size to be welded in, so the fender washer repairs wouldn't fly everywhere)
If you find you can, and decide to go for water injection, the wiper fluid tank comes in handy for that. I use mine along with a headlight washer pump for an unobtrusive seamlessly integrated homemade water injection system. (even if you find you can't use it, water injection is way easier to hide or remove-replace than an IC )
Here's me water injection - http://pg.photos.yahoo.com/ph/smoothies931pics/album?.dir=/3878
phoenix02
PostPosted: Mon Apr 17, 2006 1:24 am    Post subject: Reply with quote
Thanks alot for the pictures, and the further info on the pomona swapmeet.
I'm really hoping that the car will work out forme- if I start nearing my spending cap, I'll have to just give up and resell it, trying to get what I put out for it. The $1300 is quite litterally all I have to work on it for at least a month. Ya know, perhaps a porsche wasn't such a good idea...
We shall see.
Will water injection give me the same effect as the IC? I thought that they were complimentary, with the IC doing most of the work. Do any of you think that water injection is enough to take care of detonation with the 8.5:1 CR and 1 bar boost? If I go with the water injection and not the IC, how much is it for a stock euro spring if I start getting detonation? Would the euro make all too much difference over the US, or should I just then go with the US spring scavenged from a scrap yard?
If I put the IC on and it fails visual inspection for smog, would I have plausable deniability to say that it was available on the GTS/GTR, which was technically (very, very, very loosely stated) an option package for the Turbo? (I know they're a different car almost all together, but what smog guy will know the diff?) I know that if it can be proven that whatever mods were available for that model year of vehicle, it can normally squeak by.
Now, if you all will close your eyes and bow your heads in a silent prayer to the Porsche Gods-
"lassen Sie bitte dieses porsche das für mich, große porschegötter OH- sein auf Höhe"
(please let this porsche be the one for me, oh great porsche gods on high)
(and if that's wrong, blame google translator)
'81 Porsche 931
PostPosted: Mon Apr 17, 2006 1:46 am    Post subject: Reply with quote
http://www.snowperformance.net/ wrote:
A brief History:
Water injection was evaluated scientifically in the 1930’s by H. Ricardo who demonstrated that one can basically double the power output of an engine using water/methanol. The first widespread use was during WWII on supercharged and turbocharged aircraft. In 1942, the German Luftwaffe increased the horsepower of the Focke-Wulf 190D-9 fighter aircraft from 1776HP to 2240HP using 50/50% water/methanol injection. The allies soon followed by fitting the P51 Mustang and other high performance aircraft with water/methanol injection. Following the war, the turboprop aircraft industry used water/methanol injection and called it the “automatic power reserve system (APR)” for use in hot or high altitude take off. It surfaced again in the 60’s when GM used a system on the OEM turbo Corvair. It was used effectively in Formula 1 before being banned for adding too much power.
The latest competitive use is in World Rally Racing (WRC) where virtually all teams use it in some form and in diesel truck/tractor pulling competition.
Here're some past posts on it that may be helpful -
http://www.924board.org/viewtopic.php?t=14981&start=6
PostPosted: Mon Apr 17, 2006 3:23 am    Post subject: Reply with quote
In order to have any chance of staying within your budget:
Forget about the intercooler, sell it on ebay since your budget will not allow you to install it. (You need to have pipes and hoses fabricated.)
Try to get the stock spring for the wastegate and sell the 1 bar spring.
phoenix02
PostPosted: Wed Apr 19, 2006 12:18 pm    Post subject: Reply with quote
I just looked up the VIN on all the car research sites, and everywhere I looked came up with zero responses. Does this sound right? I thought at least change of title and smog info would be there, if nothing else...
'81 Porsche 931
phoenix02
PostPosted: Wed Apr 19, 2006 12:35 pm    Post subject: Reply with quote
Okay, I just looked up the VIN on the BAR website- there's no smog info, but the system has been wrong when I've looked up other cars. My question is, if the vehicle was moved in from out of state, I'm concerned with it being able to be smogged. If this is the case, are all 924 turbos 50 state legal, or did they sell a 49 state version without the california smog controls? If there was a 49 state, and this is one of them... I'm kinda screwed.
'81 Porsche 931
gohim
PostPosted: Wed Apr 19, 2006 4:52 pm    Post subject: Reply with quote
Maybe you have the wrong VIN number, or you typed it in wrong.
