944s in 924s ?
jesse wall
PostPosted: Sat Feb 25, 2006 1:44 pm    Post subject: 944s in 924s ? Reply with quote
anybody tried putting a 944s engine in a 924s ? problems ? thanks
jesse wall 'new driver' , 87 924s
Llamaguy
PostPosted: Sun Feb 26, 2006 5:32 pm    Post subject: Reply with quote
it has been done, should be an almost straight bolt in plus ECU. Might have trouble with the Drive shaft, but you'd need almost the entire car to do it anyways so you would just swap trannies anyways.
1987 924S Guards Red
1997 Suzuki Tl1000 Supersport
Lemming
PostPosted: Fri Mar 24, 2006 1:05 pm    Post subject: Reply with quote
Jesse,
I dropped a 968 engine in my 924S. The only issue was the brake booster which I had to move up about 2 cm to clear the intake manifold. Not sure if this will be a problem with an S motor. Other than that, it was a direct bolt in
The writeup can be found at http://forums.rennlist.com/rennforums/showthread.php?t=221429&highlight=924s3+update
Here's what she runs like, the video is from Road Atlanta a few weeks ago Click here
Tim
'95 968 (White/Cashmere)
'88 924S? (sleeper
PostPosted: Fri Mar 24, 2006 2:31 pm    Post subject: Reply with quote
Great job, I've got to try that some day!
Is the 968 motor an interference motor? Are you running the belt covers?
Lemming
PostPosted: Sat Mar 25, 2006 2:21 am    Post subject: Reply with quote
Yep, same basic engine as teh 944, only 3L and with variocam.
I don't run the belt covers, but do run the undertray.
Tim
'88 924S? (sleeper
