New LED's worked
augidog
PostPosted: Sun Mar 19, 2006 2:00 pm    Post subject: New LED's worked Reply with quote
I just recieved the second batch of LED's. 50,000 mcd . The first batch at 25,000 mcd just missed the mark. I'm happy at the results and I am moving to the overhead lighting and signal lights.
The below picture has the original bulb in on the left with the new LED's on the right.
1978 924 95 mile daily driver.
Audi TB/POR174M/High Flow Cat/2.25" exhaust
I knew that positive thinking thing wouldn't work.
PostPosted: Sun Mar 19, 2006 2:43 pm    Post subject: Reply with quote
Looks great. Are these just plug and play or are some other modifications needed?
CBass
PostPosted: Sun Mar 19, 2006 3:49 pm    Post subject: Reply with quote
Still works well with stock dimmer?
timstar92404
PostPosted: Sun Mar 19, 2006 4:23 pm    Post subject: Reply with quote
looks nice, mine are way too dark I can barely see anything at night.
did you have to take dash completely out to replace the bulbs or doyou just pop the instrument cluster out.
78 924 sold.
85.5 944
macBdog
PostPosted: Sun Mar 19, 2006 5:47 pm    Post subject: Reply with quote
Will any 50,000 mcd LED work? What value resistor did you use?
1979 931 with a 350 chev
1973 911E with EFI
p-talk wrote:
PostPosted: Mon Mar 20, 2006 12:40 am    Post subject: Reply with quote
Wow, what an improvement! Very interested to hear more, esp if they work with the dimmer...
Neil924
PostPosted: Mon Mar 20, 2006 1:19 am    Post subject: Reply with quote
Are you selling these? Are they easy to install? What's the cost?
I'm interested in being able to know my speed at night so I can at least know the numbers when I'm fighting speeding tickets in court! I have 1 point left on my license. So one more high speed flyby or rolling through a stop sign will cause me to walk for 2 months or some damn thing.
The trouble is Porsche season starts in two weeks and the Bimmer took all the ponts I was saving for the summer! DAMN IT!
ATL_racer
PostPosted: Mon Mar 20, 2006 2:06 pm    Post subject: Reply with quote
i think there is enough interest for a DIY on LED guages...lets see how to do it
late 1979 porche 924, red 2.0l NA 5speed snailshell
Plans: Restore exterior, revitalize interior, install killer sound system, run engine in stock form and have fun.(+ a short throw shifter if i can find one)
Neil924
PostPosted: Mon Mar 20, 2006 2:32 pm    Post subject: Reply with quote
If by "DIY" you mean call my mechanic and have him do it, yes, let's get this process down on paper. I assume differnt colours can be had???
PostPosted: Mon Mar 20, 2006 2:49 pm    Post subject: Reply with quote
You may be able to use differnt colors, maybe blue, or green... However I think red has a weird reaction with most gauge clusters where it wont show through or something. I could be wrong though, thats just how it was with my last car.
But yes a quick DIY. More money that can be spent!!!
Neil924
PostPosted: Mon Mar 20, 2006 2:56 pm    Post subject: Reply with quote
Does the dimmer still work?
augidog
PostPosted: Tue Mar 21, 2006 10:54 am    Post subject: Reply with quote
$16.50 for 50 shipped with 510-ohm resistor ready for 12 volt.
They have a 25-degree angle.
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&ssPageName=ADME:B:EOIBSAA:US:11&Item=7579727792
I wanted to keep them plug and play so I modified the holders very little. They can easily be unsoldered and take oem bulbs again.
There is a little trick with a hot pin to isolate the contacts through the plastic housing.
I'm working on the dimmer problem now. I should be able to use the oem pot wheel.
I did the overhead with 2 led’s and it works well. It sheds a very cool blue white light.
It’s very easy to do. I removed the steering wheel and pulled all three gauges and plastic bezel as a unit.
Neil924
PostPosted: Tue Mar 21, 2006 1:22 pm    Post subject: Reply with quote
Isn't 50 a lot?
PostPosted: Tue Mar 21, 2006 1:28 pm    Post subject: Reply with quote
Those little fellas put out UV photons, so don't shine 'em right into your eye while playing with them. Flashlights that use them normally include a warning about it.
Neil924
PostPosted: Fri Apr 14, 2006 12:24 pm    Post subject: Reply with quote
Does that mean, once they are installed we can't/ shouldn't look at them? The lights point outwardly... the driver is outwardly....
