OT- Airplane Riddle?!!
Goto page 1, 2, 3, 4, 5, 6  Next
Will the plane ever take off?
Yes
50%
 50%  [ 13 ]
No
50%
 50%  [ 13 ]
Total Votes : 26
PostPosted: Sat Dec 03, 2005 6:40 am    Post subject: OT- Airplane Riddle?!! Reply with quote
An Airplane propelled by a jet engine is on a runway that acts as a treadmill. The faster the plane puches it self the treadmill counteracts the motion. Therefore if the airplane is pushing at 100 mph north, then the runway is moving 100 mph south.
The Question:
Will the airplane take off?
Explain
Ozzie
PostPosted: Sat Dec 03, 2005 7:18 am    Post subject: Reply with quote
There is no air moving over the wings to create lift.
Its AUTO and its BLACK
Montego Black on black/red
PostPosted: Sat Dec 03, 2005 8:29 am    Post subject: Reply with quote
some jet airplanes get airborne and land verticaly
all jet airplanes have a control jet direction sistems so the actual jet changes its angle compared to the plane itself...
the threadmill moves at 100mph...well that movment would move some air in its nearby space...
so there is some air moving under the plane...the jet can be pointed down...i guess it could actualy take off
ALL THIS IGNORING THE INERTIA OF THE THREAMILL(MUST BE A HEAVY THING TO SUPPORT THE PLANE) AND FRICTION BETWEEN THE PLANE AND THE THREADMILL PLANE,WICH IS HIGH AND WOULD MAKE THE PLANE JUST SHOOT OFF IT
so...theoreticaly...maby the plane would stay on the threadmill....practicaly...NEVER
chris24
PostPosted: Sat Dec 03, 2005 8:38 am    Post subject: Reply with quote
Bernoulli effect ( fluid with higher velocity has a lower pressure) and Newton's 3rd Law (action-reaction is opposite but equal).
1. Bernoulli Effect: The wings of a plane are flatter on the bottom than the top. This means that there is a greater distance to travel on the top than the bottom. Giving rise to the popular theory that the increased velocity at the top gives a lower pressure above the wing and so a force upwards - lift. ((However, to get the acceleration you need a lower pressure to start with!))
2. Newton's 3rd Law: The air that flows over the top of the wing sticks to the wing (?Coanda effect) and as the top of the wing angulates downwards, once the air has reached the end of the wing it continues in its path of movement (conservation of momentum). This downward flow or force requires an opposite (upward) force that equal (Newton's 3rd Law).
And so it is a mix of these two that keep planes in the air and generate lift.
Right?
1983 - 924 (185K miles) - not mint
1985 - 924 (148K miles) - mint
1990 - 944S2 cab (52K miles)
WhoDak
The engines would be moving the air through the turbines fast enough to displace enough air it wouldn't be able to stay in one spot on the runway would it?
Mike
'82 924 N/A
'91 Toyota Pickup SR5 4x4 Xtra cab
chris24
PostPosted: Sat Dec 03, 2005 8:40 am    Post subject: Reply with quote
a jumpjet...nice lateral (or vertical) thinking morghen.
Andrew NZ
PostPosted: Sat Dec 03, 2005 9:11 am    Post subject: Reply with quote
Of course it would, its just that the wheels would be spinning twice as fast as normal until it leaves the ground!
The last time I looked at a plane the wheels were'nt driven by the engine so what speed the ground is going past is irrelevant - the jet engines push through the air.
Andrew
1977 RX924 race car
12a bridgeport supercharged
www.race4-dcup.co.nz
Khal
PostPosted: Sat Dec 03, 2005 9:25 am    Post subject: Reply with quote
Agree with Ozzie.
If the 'plane is not moving forward through the air, it cannot take off.
'80 924 Turbo
Neil924
PostPosted: Sat Dec 03, 2005 9:58 am    Post subject: Reply with quote
It would probably lift {taking weight off the wheels} but I don't know if it has enough eumphh! to actually leave the ground. And if it did, it would be a very short and bouncey trip.
PostPosted: Sat Dec 03, 2005 10:19 am    Post subject: Reply with quote
I agree with Andrew as long as the treadmill or the runway at the end of the treadmill is long enough for the plane to achieve lift off speed. (I hope my years of Aerospace Engineering at Penn State helped me make the right decision....)
Neil924
PostPosted: Sat Dec 03, 2005 10:40 am    Post subject: Reply with quote
They taught you Areospace Engineering in a State Penitentiary? Wow!
tj924
PostPosted: Sat Dec 03, 2005 11:43 am    Post subject: Reply with quote
But the point is that the plane is remaining stationary (not physically possible, but thats not the point). It needs significant forward movement to achieve flight, so I'd think it would remain on the tradmill.
TJ
Silver '82 924 NA 5-Speed Manual
Andrew NZ
PostPosted: Sat Dec 03, 2005 11:49 am    Post subject: Reply with quote
Perhaps it should have been worded differently then?? There's nothing there that says the plane isn't, or can't move, is there?
Andrew
1977 RX924 race car
tj924
PostPosted: Sat Dec 03, 2005 11:52 am    Post subject: Reply with quote
Andrew NZ wrote:
...There's nothing there that says the plane isn't, or can't move, is there?
How about:
Flosho wrote:
...The faster the plane pushes it self the treadmill counteracts the motion...if the airplane is pushing at 100 mph north, then the runway is moving 100 mph south
I thought that implied no forward motion.
TJ
PostPosted: Sat Dec 03, 2005 11:55 am    Post subject: Reply with quote
That doesn't matter, unless the pilot has full brakes applied!
Page 1 of 6
