Hole in trans.
Gram
PostPosted: Tue Sep 27, 2005 10:11 am    Post subject: Hole in trans. Reply with quote
Just jacked my car up and put it on stands, took the rear wheels off to adjust the rear linings and have a look around the trans. I notice there's a 1" or so hole open into the side of the trans, above and forward of the filler hole. With a flashlight I can see a bit of the linkage, and in Haynes P. 152 it shows that I'm looking at the shaft and shaft connecting sleeve. Surely there should be a bung of some sort over this hole to keep dust and crap out? Do you suggest I get a metal bung or just glue a rubber grommet in there? Is there a part number for this bung? TIA.
'82 924 NA Euro (hers)
'98 Audi A4 TDI (ours)
jpab924
Location: Crown pt. IN. 50 miles southeast of Chicago Ill.
PostPosted: Tue Sep 27, 2005 1:55 pm    Post subject: Reply with quote
One of those expandable rubber freeze plugs should do da trick! Hopefully you know what I`m referring to.
PostPosted: Tue Sep 27, 2005 2:02 pm    Post subject: Reply with quote
What the heck did you loose your rubber bung hole cover lol
man should we all check our rearends for bung hole covers
hhmmm whats the story here.
Gram
PostPosted: Wed Sep 28, 2005 7:06 am    Post subject: Reply with quote
jpab..don't really. Freeze or frost plugs I thought are usually metal caps that are hammered/glued into casting holes in the block. I'm sure originally the trans had a metal cap too. A rubber plug will be better than nothing I guess..
Gram
PostPosted: Wed Sep 28, 2005 7:08 am    Post subject: Reply with quote
Relax Joe..I think this hole is so you can separate the drive shaft when you pull yr trans, but I might be wrong.
PostPosted: Wed Sep 28, 2005 9:30 am    Post subject: Reply with quote
I think jpab might be referring to something like one of these - http://pg.photos.yahoo.com/ph/smoothies931pics/detail?.dir=341f&.dnm=f1e2.jpg&.src=ph
-can usually be found at a hardware store, most likely near the plumbing stuff.
Gram
PostPosted: Wed Sep 28, 2005 10:25 am    Post subject: Reply with quote
OK thanks..never seen those but I'll start looking. Wonder what was originally covering that hole..Audi 016/9 trans.
PostPosted: Wed Sep 28, 2005 10:37 am    Post subject: Reply with quote
"cap" part number 477.521.177 should have been in there originally.
PostPosted: Wed Sep 28, 2005 1:16 pm    Post subject: Reply with quote
yea listin to smoothie I was just maken a joke..didnt mean
nothin at all by it..
Gram
PostPosted: Wed Sep 28, 2005 7:58 pm    Post subject: Reply with quote
Thanks for the part number Smoothie..I found a rubber grommet that fitted fine so that'll do for now.
