Wire Harness
Warped
Guest
PostPosted: Tue Apr 16, 2002 3:50 pm    Post subject: Reply with quote
Hello,
Is this myth or fact? I was talking to a friend at work that mentioned the idea of purchasing a complete packaging of all the wires within the car called a wire harness. It would be semi already connected, and you could just lay it all out in your car, and replace everyone of your wires with the new ones.
This sounds almost to good to be true? especially when almost every one of my wires is cracked and in need of being replaced...I'm sure.
If this is true, where would I get something like this? I'm sure NAPA, or your everyday Auto store would not carry it.
TroyDest
Guest
PostPosted: Wed Apr 17, 2002 5:54 am    Post subject: Reply with quote
Yes, it's true that you can get a complete wire harness that is already assembled with connectors and wire covering. But the only possible place to get it new would be the dealer and it would be way too damn expensive! If you don't want to tackle the wires yourself, you might get lucky and either find a car at a wrecker or get the harness from someone who is building a racer and has removed the wires. Good luck, Troy.
PostPosted: Wed Apr 17, 2002 6:45 am    Post subject: Reply with quote
Do you really think another used 20-yr old set of wires would have less problems than yours? Maybe. Or you could fix problems as you find them with new wires.
'79 924 #77 ITB racecar
kyhm
Guest
PostPosted: Wed Apr 17, 2002 10:52 am    Post subject: Reply with quote
I went this route last summer. Before the rebuild I had flaky lights, flickering gauges, intermittent ignition problems, "ghost" wipers, and lots of other problems.
I pulled the dash harness out, replaced all wires which were vsibly discolored or had unreasonably high resistance. Also integrated my alarm, new stereo, and driving lamps at the same time, and re-arranged some existing circuits...
It seems to have exterminated the the car's electrical gremlins, plus I have an alarm that's very difficult to bypass and lights that behave the way I want.
