Vacuum Test Gauge
Goto page Previous  1, 2
Khal
PostPosted: Thu Sep 15, 2005 6:52 pm    Post subject: Reply with quote
An '82... you sure you don't have DITC? I thought all from '81 on had DITC? Mine does (I know, it's a Turbo, but I thought even the NA's got it)
'80 924 Turbo
tj924
PostPosted: Thu Sep 15, 2005 6:54 pm    Post subject: Reply with quote
It's in the Factory Manual that only US (& I think Canadian) NA cars got DITC with EIS
TJ
Silver '82 924 NA 5-Speed Manual
Ozzie
PostPosted: Thu Sep 15, 2005 7:01 pm    Post subject: Reply with quote
I'm pretty certain I don't have DITC and I know definitely I dont have EIS.
Its AUTO and its BLACK
Montego Black on black/red
Khal
PostPosted: Fri Sep 16, 2005 12:50 pm    Post subject: Reply with quote
tj924 wrote:
It's in the Factory Manual...
Yeah, but what's in the car? Are you sure you don't have DITC?
'80 924 Turbo
Gram
PostPosted: Fri Sep 16, 2005 1:31 pm    Post subject: Reply with quote
'82 NA has TCI-H ignition..no EIS. Think the DITC was only on the turbos..
'82 924 NA Euro (hers)
'98 Audi A4 TDI (ours)
Khal
PostPosted: Fri Sep 16, 2005 3:19 pm    Post subject: Reply with quote
No worries. Just checkin'. As much for my own info as anything
'80 924 Turbo
PostPosted: Fri Sep 16, 2005 11:17 pm    Post subject: Reply with quote
you'd know you have D-ITC if you have a single blade throttle body...
If you have TCI-H you should have EIS with the two microswitches on the dual plate throttle body...
otherwise it's a standard inductance transmitter .... or being an australian 924 it could be any combination from previous years that works...
EIS part number : 211 905 351
or non turbo idle stabiliser unit : 477 906 083
distributor code should be:
non-turbo 477 905 203
I can't find anything that relates to a non vaccum operated distributor?? So I guess that the T-CIH ignition curve may counter for the lack of vaccum advance ??
Leadfoot
tj924
PostPosted: Sat Sep 17, 2005 1:20 am    Post subject: Reply with quote
Actually I think the factory manual says TCI-i with no EIS for Aus-delivered (& at least some other RoW models as well). I'll have to drag out the factory manual PDFs I have & check tomorrow. Based on the factory manual I'm assuming I have the TCI-i ignition & I absolutely have no EIS. Build plate says June '82, so its definitely an '82.
It was actually Smoothie who first found the cap for the distributor vacuum unit for Aus cars. Can't find it in PET right now so maybe it was in the factory manual as well. Anyway, I know I did find it & it confirmed what I'd found on my car (ie NO vacuum lines connected to the vacuum unit on the dizzy & the vacuum port capped).
TJ
Page 2 of 2
