catalytic test pipe
cs
Guest
PostPosted: Wed Aug 15, 2001 3:04 pm    Post subject: Reply with quote
does anyone know where i could get a test pipe for a 931. would i be better off just going to a good muffler shop and having them make me one.
larso
Guest
PostPosted: Thu Aug 16, 2001 3:21 am    Post subject: Reply with quote
What are you going to do about the wastegate out pipe, since it enters right into the cat?
I would get a test pipe, or a cherry bomp cigar muffler in place of the cat, and put a seperate straight pipe from the wastegate pipe out the back
cs
Guest
PostPosted: Thu Aug 16, 2001 5:43 am    Post subject: Reply with quote
yeah that's the biggest problem i'm having is that the waste gate goes right into it. i saw a test pipe for sale at AA, but that's out of the question. i think a good shop could rig something up. maybe cut off the old connector and weld it onto a straight peice of pipe.
Dave
Guest
PostPosted: Thu Aug 16, 2001 1:56 pm    Post subject: Reply with quote
What happens If you just dont connect the wastegate to anything. Just run a pipe to nothing.
larso
Guest
PostPosted: Thu Aug 16, 2001 2:45 pm    Post subject: Reply with quote
yes, as long as you rout it to the back of the car Dave.
It will sound nice.
I think the wastegate pipes should be bigger than they are...your wastegate opens up at high RPMS, so get a bigger pipe if u want.
numbers
Guest
PostPosted: Sat Aug 18, 2001 7:26 am    Post subject: Reply with quote
You probably wouldn't notice any difference with a test pipe, because your cat probably doesn't have anything in it. The ceramic that the catalyst was attached to gets hard and crumbles after a few years, and it all goes out the tail pipe. To check it, just remove your cat and look inside with a flashlight. You probably just have a hollow 3 1/2 shell. Better than any test pipe, and your waste gate pipe still fits. If there is still anything in your cat, just take a long screwdriver or some other long metal rod, and break it up an dump it in the trash.
larso
Guest
PostPosted: Sat Aug 18, 2001 8:09 am    Post subject: Reply with quote
cat's r heavy though and they still aren't as smooth flowing as a pipe right? since the exhaust has to go through something big for a few inches, and then go into something small when it hits the end of the cat.
924 turbo
Guest
PostPosted: Sat Aug 18, 2001 10:55 am    Post subject: Reply with quote
Hollow the cat out if you don't have to worry about emissions. Everything else is too expensive for the small difference it will make.
Michael Kouridakis
Guest
PostPosted: Tue Aug 28, 2001 4:06 am    Post subject: Reply with quote
My car ('82 931)just passed the NJ inspection for emissions. My car still has the original cat and all pipes. I wonder if the cat has any catalyst left in it. I can't believe that it passed. Turbos kick booty.
-nick
Guest
PostPosted: Tue Aug 28, 2001 4:17 am    Post subject: Reply with quote
my '77 cat was actually in pretty good shape before i gutted it out a while ago. it took some muscling to get all the ceramic out. i always thought they were pretty indestuctible. have you had problems with them in the past?
-nick
