jeanmanu Guest
Posted: Sat Aug 25, 2001 2:34 am Post subject: |
Hi,
I have some pb with my 79'924.
When the engine get warm and if I don't drive with it, there is no leaking. When I make around 20 miles, the Oil begins to leak at the hole of the clutch (below the car). I can also some oil around the hole of clutch (inside the engine). The clutch seal has been changed and I suspect the water gasket to be dead.
A lot of oil recover the starter motor.
Please, I need some help!
JM |
