Check out this 2.5L!!!
garthfan
PostPosted: Tue Feb 22, 2005 1:43 pm    Post subject: Check out this 2.5L!!! Reply with quote
Found this post over on the Pelican board and thought I'd share it with y'all:
http://forums.pelicanparts.com/showthread.php?s=&threadid=205488
What a sight to behold!
1987 924S - Was a daily driver...now it's GONE! *sniff*
1986 944 N/A Guards Red
1996 VW Jetta Grocery-Getter
1995 Saab 900S Winter-Driving-Feeling-of-Security-Vehicle
PorschePlatz
PostPosted: Sun Mar 06, 2005 12:36 pm    Post subject: Reply with quote
Amazing what a little rattle-can action can produce.
Always Broke
garthfan
PostPosted: Mon Mar 07, 2005 11:53 am    Post subject: Reply with quote
Ahh, no.
The engine's from Broadfoot Racing. If you actually read the info on this link instead of just looking at the pictures, you'll understand why it looks so good. Broadfoot builds the entire motors from the ground up. New bearings, new seals, every gasket new, heads are cleaned up and faced as are the blocks, new front-end work...in other words, you get a pretty much brand new engine.
And it's not all spray paint. There's a lot of good powder-coat work in the proper places (meaning the parts that won't keep paint under high-temp).
This is off the eBay page:
PORSCHE 944 Engine
Rebuilt by Broadfoot Racing
New Rebuild with 0 time.
12 month or 12,000 mile Warranty if used in street car. No warranty if used in race car.
Built off 1987 Block
Stock Rebuild (150 HP)
Silicon / Carbide Honed Cylinders
New Rings
New Main Bearings
New Rod Bearings
New Balance Shaft Bearings
Micro polished std. size Crank
Complete 3 angle valve job
Rebuilt Oil Pump
New Water Pump
New Cam Belt
New Balance Belt
New Adjuster and Idler Pulley's
New Hydraulic Lifters
Cam Tower Powder Coated Red
Intake Manifold and Oil Pan Powder Coated Silver
All new Seals and Gaskets
Show Car Condition with all new Hardware
Power Pulley's
So...how's that, hoss?
