Lousailor Guest
Posted: Thu Mar 14, 2002 5:02 am Post subject: |
Ok it's finally time to bite the bullet and pull apart the front end. I'm going to replace the front bushings, and shocks and possibly upgrade the springs. I don't really want to change the stock ride height, but I do want to tighten up the ride (daily driver, no racing). I'm going to do most of the work myself, probably followed by a professional alignment. What is my best bet if I don't want to spend an arm and a leg? I was looking at Boge/Sachs inserts/shocks with 220 lb H&R springs. Do I need to install snubbers as well? Should I think about replacing the sway bar or rear torsion bar? Thanks. It'll be a long road to make my junker a curb queen, but I'm finally getting some free time to get the work done.
Joined: 29 Jul 2001 Posts: 8813 Location: Royal Oak, MI, USA
Posted: Fri Mar 15, 2002 12:58 am Post subject: |
You'll likely want swaybar upgrades. I've heard the front springs are popular, but you'll want to add more rear swaybar or torsion bar to compensate, or the car will understeer more (all else being equal). One option, which I personally like very much and have on my racecar, is the 19mm adjustable 944 Cup Car bar, aka the M030 rear bar. You'll be able to decide how much bar you want. It's also very inexpensive, at about $140 with bushings last I checked, and higher quality than the Weltmeister bars (since it's an original Porsche part).
If you really want much flatter cornering, you may need a bigger front bar as well, necessitating a bigger rear bar than 19mm, which means Weltmeister front and rear. Replacing the rear torsion bars and front springs could do the same thing, but would give a stiffer ride as well (swaybars impact your ride much less), and the torsion bars are very painful to replace - requires a lot of time and effort, not to mention trial and error to get the correct ride height afterwards. BTDT. I suspect you'll just want swaybars.
Shocks are like religion, everybody's got their thing. I'm in the process of putting Bilsteins on my turbo.
Lousailor Guest
Posted: Sat Mar 16, 2002 4:56 pm Post subject: |
Thanks Vaughan, i'll let you know what I end up with. |
