interior panels
Jrod-13
PostPosted: Mon Mar 11, 2002 11:15 am    Post subject: Reply with quote
does anyone know a easy and non destructive way to remove the rear side panels on a 78'924, to gain access to the speakers?? It seem the panels are glued to the body?? and they start to rip when being removed.. is theis and eaiser way to do this?? thanks,
Jared
baldwin
PostPosted: Sat Mar 16, 2002 7:29 am    Post subject: Reply with quote
Maybe this will help:
http://www.connact.com/~kgross/FAQ/944faqst.html
Vince Ponz
PostPosted: Sat Mar 16, 2002 7:41 am    Post subject: Reply with quote
I removed and replaced the speakers without destroying the part. You need a very small screwdriver and two good left hands. You can do it but it takes patience. Pull away the front of the panel and using the very small screwdriver remove the screws. Reverse the method and it may take some time but I did it and so can you. Good luck.
