Mich924S Guest
Posted: Mon Feb 04, 2002 2:47 am Post subject: |
Anyone know of any reputable and reliable short throw shifter kits for the 924S and where I might purchase it from? |
Joined: 29 Jul 2001 Posts: 8804 Location: Royal Oak, MI, USA
Posted: Mon Feb 04, 2002 5:53 am Post subject: |
There's only one option I'm aware of, that everybody sells, which is the Weltmeister kit. You can buy it from Paragon Products, or Performance Products/Automotion, or Tweeks - I think they all carry it...
numbers Guest
Posted: Wed Feb 06, 2002 8:09 am Post subject: |
Anybody ever find one for the snailshell? |
Posted: Thu Feb 07, 2002 12:48 am Post subject: |
No, no such luck. You'd have to fabricate your own. I've seen interesting versions...
numbers Guest
Posted: Thu Feb 07, 2002 7:51 am Post subject: |
Well, if I ever get a round tuit I will post it here. |
1987924S Guest
Posted: Fri Feb 08, 2002 6:06 am Post subject: |
If you havn't noticed, your shifter is just a solid piece of metal. if you want a shorter throw distance, just pull the shift knob off and cut part of the shifter off. Its that simple. Its the same thing as buying a short throw from an aftermarket dealer. |
Posted: Fri Feb 08, 2002 8:58 am Post subject: |
No, sorry, it's not. First thing, the short-throw kit replaces 80% of the parts in the linkage responsible for shifter slop with solid heim joints, resulting in an extremely tight-feeling, positive, shifter. Secondly, the shifter design in the 924/944 is not a screw-on knob, so re-locating a knob on this car is not so easy.
ricomartinez Guest
AppleBit
ricomartinez Guest
Posted: Sat Feb 09, 2002 10:39 am Post subject: |
I know that. I just wondered what kind of improvement it makes. Fifty bones isn't a whole lot and it looks like a relatively easy mod. If it makes a noticeable difference, it will be worth it. Good, tight shifting is such a plus for the motoring experience.
Let us know how it works out. |
Joes924 Guest
Posted: Thu Mar 07, 2002 3:47 pm Post subject: |
so will the dst 944 shift kit fit the 016z
Great One Guest
Posted: Mon Mar 11, 2002 6:33 am Post subject: |
Has anyone installed the performance products short shift kit? I ordered one and it had no directions. |
HRK Guest
Posted: Tue Mar 19, 2002 4:52 am Post subject: |
Applebit, tell us how you like your crispier shifting.
