cakemakerman Guest
Posted: Sat Mar 09, 2002 2:29 am Post subject: |
Has anyone thought about putting a high performance rotory engine in a 924. I want to do this. If anyone has experience in this please talk to me. I want to put a natural gas rotory engine in my 924 and convert it to burn H2. |
dwak Guest
Posted: Sat Mar 09, 2002 6:22 am Post subject: |
I thought h2 engines were still a pipe dream and I believe there are a lot more rotary-less Mazdas out there than Mazda less rotary engines.
teo
Joined: 07 Sep 2001 Posts: 637 Location: Hungary, Europe
Posted: Sat Mar 09, 2002 6:48 am Post subject: |
Here is a Mazda-less rotary engine:
and it will fit anywhere |
cakemakerman Guest
Posted: Sat Mar 09, 2002 7:52 am Post subject: |
actualy all major car manufacturers are working on hydrogen engines and building prototype cars, mazda, ford, bmw, etc. however so far i have not found any h2 engines for sale |
Cbass Guest
Posted: Sat Mar 09, 2002 11:31 am Post subject: |
BMW has a 7 series that runs on hydrogen. I saw it my R&T issue this month. It's a stock engine, they just converted the fuel system to hydrogen and used the injectors to control the spray.
As for a rotary, I know an awful lot about this subject . What you'll want is a Mazda 13B, the second most common rotary in the world. The most common is the 12A. Avoid this motor like the plague, as it is heavy, unreliable, guzzles gas, and has next to no power potential.
Get a turbo 13B and you'll be fine. Or a 20B, depending on where you are. We never got the 20B in North America, but the Japanese and Australians did, I'm not sure about the Europeans. The 20B is a triple rotor variant of the 13B, which has two rotors. Any 13B from 83 and up is good, with the preference being the 86-92 single turbo RX-7 motors, as they have the cheapest power potential.
Phew, another ridiculously long rant. |
Cbass Guest
Posted: Sat Mar 09, 2002 11:33 am Post subject: |
Oh yeah, these are very compact engines, with a traditional flywheel clutch system. It'll definately fit, and I'd be happy to give you any advice you need. |
wdb Guest
Posted: Sat Mar 09, 2002 12:21 pm Post subject: |
better get a BIG fuel tank , idustrial bottle gas suppliers are not that abundant,might be a long drive between fillups . oh and I think its expensive, and the feds dont like it when individuals buy bottled hydrogen , makes them nervous. and you need to take hazmat classes to get the permit to transport it. and the gaskets are notorious for leeking , seems its hard to find a material that is soft at 400 below zero F SEE NEXT POST
[ This Message was edited by: wdb on 2002-03-09 13:25 ] |
wdb Guest
Posted: Sat Mar 09, 2002 12:23 pm Post subject: |
Posted: Sat Mar 09, 2002 2:35 pm Post subject: |
a rotary in a 924? Been done before. It's called an RX7 |
Cbass Guest
Posted: Sun Mar 10, 2002 12:34 pm Post subject: |
Heheh. It's funny cause it's almost true.
God damned f***'n mazda. Sorry. Umm, hydrogen isn't that hard to do. I'd just stick with gas for now, and let the R&D people build good conversion kits.
Rick MacLaren Guest
Posted: Tue Mar 12, 2002 1:05 am Post subject: |
If you want maximum boost for a 931 engine, convert it to propane and then turbocharge it. |
Cbass Guest
Posted: Tue Mar 12, 2002 7:47 pm Post subject: |
Gaahhh!! Propane? Guess it has better compression qualitahs. Sorry, can't communicate the accent. |
JvGinPDX Guest
Posted: Wed Mar 13, 2002 3:34 pm Post subject: |
Fuel cell companies are working on hydrogen projects. Ford and Chrysler are into it, along with Mercedes. It may be possible to buy hydrogen in a few years at your uh, gas station. BMW does indeed have a hyrogen powered internal combusion engine going on sale in Germany soon. Your idea sounds far fetched. I will go still farther. In ten years it will be possible to go to a wrecking yard to convert our elderly 924 cars to hydrogen fuel cell power, and have electric drive. |
cakemakerman Guest
Posted: Thu Mar 14, 2002 1:27 am Post subject: |
So these bmw engines, is there a way I could order one. From my understanding they can either burn H2 or gasoline with the flipp of a switch. So you think its improbable to but one of these hummers in my porsche? Why can't I be one of the first persons to drive a H2 powerd porsche? |
JvGinPDX Guest
Posted: Thu Mar 14, 2002 10:18 am Post subject: |
The problem is that hydrogen is not available for automotive use to the general public. At least, not yet. In Germany, it will be in the near future. Try the websites for Ford and Daimler-Benz. Type in fuel cells. Also try Ballard Power. Also Hydrogen Investor. It is a real eye opener. In ten years, you will be able to do what you want. Or you could just go to the Ford or Chrysler dealer to buy a new hydrogen powered car. Most manufacturers are working on this issue. |
