poor starting 924
thonglover
PostPosted: Mon Oct 25, 2004 7:19 am    Post subject: poor starting 924 Reply with quote
my 1984 924 has very bad starting problems the engine turns over very slowly sometimes not at all i put a new battery in on saturday which seemed to help but very little change in turnover just turns longer.
went out and started today with little problem but after turning off it won't even crank the engine just a click from somewhere under the bonnet.
starter was reconed a year ago could it be that?
I appreciate any help thanks.....Rab
Neil924
PostPosted: Mon Oct 25, 2004 7:44 am    Post subject: Reply with quote
Post relocated.
Sleykin
PostPosted: Mon Oct 25, 2004 8:36 am    Post subject: Reply with quote
Sounds like a conectivity problem. Check and clean all the connections from the battery to the starter and the battery to the ground points.
Then post the results in the general section and we can go from there...
Glenn Neff
Medford, OR
87' 924S
PostPosted: Mon Oct 25, 2004 3:58 pm    Post subject: Reply with quote
add a new ground wire to the engine from the chassis, or the battery.
3 928s,
