Correct way to set my timing.
PostPosted: Mon Sep 27, 2004 2:09 am    Post subject: Correct way to set my timing. Reply with quote
it runs 'Ok' though Im thinking its to retarded so
Ill set the timing mark dead on with the gun then the book say '-3'
at 950rpm is that retarded 3 ' seems it should be advanced 3'.
Im stuck here.
Is there any way to check advance timing at a given rpm with gun
a have a dial for preset timing advance settings guess I just hook it up and unhook the vacuum dizzy tube and rev it up to 4500 rpm set with 41 'advance.
Someone help me here I want to get this done today. K
FrankNL
PostPosted: Mon Sep 27, 2004 2:45 am    Post subject: Reply with quote
You would like to have a spark BEFORE BDP! So -3 will be 3 degrees before BDP, so before the 0 mark on the flywheel.
Porsche 944 turbo '87 - maranchino red
Porsche 924 '84 - guards red
augidog
PostPosted: Mon Sep 27, 2004 11:48 am    Post subject: Reply with quote
Joe,
Look at your manual. With the -3 and the vacuum hoses attached your running actually 3-4 btdc because of the vacuum retard of 7-8 degrees.
Distributor = 30 degrees
Distributors mechanical advance = 6
Static timing = -3
So, to run 41 degrees full advance set it at 2 atdc with vacuum hoses attached. No more than that or you will ping at high rpms
distrib plus mech advance = 36
-3 is static
Vacuum retard 6-8
-3 your actually running at 4 btc with vacuum retard disconnected
4 plus 1 = 5
36 plus 5 = 41
5 is optimal with vacuum hoses disconnected but check your full advance to be sure. 6 btdc and you will ping at 42 degrees.
If all else fails, set it at -3 atdc vacuum hoses connected to be safe. Then you will have no danger of pinging. Your full advance will only be 40.
Anyone who sets 0 or higher " with" vacuum hoses attached will eventually damage the engine.
My vacuum was weak so I had to recalculate from the book. I’m only retarding 6 degrees on my distrib.. That’s why you should do a full advance test to be safe and sure because every car is in slightly different running shape.
Jazzerpet
PostPosted: Mon Sep 27, 2004 12:01 pm    Post subject: Reply with quote
Augidog, very well put. I will save this info for future reference. I am still amazed at the vast knowledge of our board members.
1985 ½ 944
Member of the “Omaha Crew”
PostPosted: Tue Sep 28, 2004 11:22 am    Post subject: Reply with quote
K I put some paint in the flywheel mark that helped..set it 3
and drove it to work and amn it was nice. I have to thank you
guys for all the imput all i did was study the manual and though Id ask here.
Thanks.
Lizard
PostPosted: Tue Sep 28, 2004 3:31 pm    Post subject: Reply with quote
well about 6 deg BTDC is the sweet spot according to Vaughan, which is roughly where I run mine, I really find it hard to look in that small window at the back and I always just tune it by ear and how it responds when I blip the throttle.
3 928s,
PostPosted: Fri Oct 08, 2004 12:08 pm    Post subject: Reply with quote
Well I set it at 2 degrees. Hey I took a nice pic of the little window last weekend also. Ill upload after I get back goin out for a little ...anywho
Ill show you guys where Im aiming at in the window K when I upload the pic.
PostPosted: Fri Oct 08, 2004 2:47 pm    Post subject: Reply with quote
Ok heres what I did hooked up the leads to the battery tyhen clamped the
timing light wire to the #1 cyl. lead set my adjustable timing light at 2-3
then lined up the zero with the mark that the blue pointer I added in the pic
points to on the bellhousing. thats with the vac lines still connected..runs not bad doesnt ping
So do I need to set my adjustable advance timing light at 6 then put the
zero mark on the flywheel to the point on the bell housing.
PostPosted: Sat Oct 09, 2004 12:34 pm    Post subject: Reply with quote
come on does the arrow point to the right spot.
Roger
PostPosted: Sat Oct 09, 2004 12:57 pm    Post subject: Reply with quote
I have the same mark, I have allways used it as TDC
1981 924 NA
Some people are like Slinkies. Not really good for anything, but you
still can't help but smile when you see one tumble down the stairs.
augidog
PostPosted: Sun Oct 10, 2004 12:48 am    Post subject: Reply with quote
Joe,
If that is the 0 tdc mark than whatever you set your advance timing light to, that mark will be centered in that window.
For example your timing light is set to 0
if you center that mark you will be at 0
If your timing light is set to 5 btc, than you line up the same mark in the window you will be at 5 btc.
remember 5 btc vacuum lines disconected- or-
-2 atdc with vacuum lines attached.
Timing is everything.Its my passion with this car to get it just right.
Goodluck.
PostPosted: Sat Oct 16, 2004 11:42 am    Post subject: Augidog Reply with quote
Augidog When you said this it kind of looped me 'well' I
followed the first part where you wrote remember 5 btc vacuum lines disconected I can do that with my timing light how do I do it with
my light to -2 atdc with vacuum lines attached. It would be best to go
to (0) with my light then retard it a bit............ What I did was set it to 5 with out removing the dizzy lines. So instead of going to Zero then retarding a bit maybe Ill just start it up and remove the dizzy lines
set the gun to 5 and set it and try it... I need the sweet spot.
Goodluck.
____________
augidog
PostPosted: Sat Oct 16, 2004 12:11 pm    Post subject: Reply with quote
Joe,
If you can set to -2 with your advance timing light, than the 0 mark is actually -2 because the timing light is compensating to that degree.
Whatever you set the timing light to- the 0 mark in the window is that timing.
For instance:
5 btc set on your timing light -is now the 0 mark in your window
-2 on your timing light- is now the 0 mark in your window.
With vacuum lines disconnected to the distributor, put it at 41 degrees and rev at 4500 the 0 mark should be in your window and you just checked your full advance.
