Fire away... its gonna be fit.
PostPosted: Thu Aug 12, 2004 3:12 pm    Post subject: Fire away... its gonna be fit. Reply with quote
I know i know.. its bad I guess well its gonna be fit nice.
PostPosted: Tue Sep 07, 2004 3:38 pm    Post subject: Reply with quote
This labor weekend I took the time and refit the used 944 valance.
Hows it look?
mikecoupegt
PostPosted: Tue Sep 07, 2004 4:04 pm    Post subject: Reply with quote
It looks good. How did you fit it to the fenders?
5150
PostPosted: Tue Sep 07, 2004 5:41 pm    Post subject: Reply with quote
Looks a lot neater Joe, lines look much better than before. Nice job
Mars Red '78 Euro 924 n/a
http://www.cardomain.com/id/5150_uk
Graphite? Grey Metallic '85 (late model) 944 2.5
There are two kinds of pedestrians: the quick and the dead.
PostPosted: Sun Sep 12, 2004 10:50 am    Post subject: Reply with quote
Looks better huh. Cant wait to get it painted got to fix the fuel pump first.
PostPosted: Sun Oct 03, 2004 11:28 am    Post subject: Reply with quote
Spent my saterday out in the drive doin body work .. tires were rubbin last week I had to cut the lip of the fenders. i cut the lip off where it turns inwards along the top so today I smoothed it out with some thing called Easy Sand by evercoat its a polyester blending putty in a tube you just mix in the hardener. Someone has the digi cam so I have no pics. Ill take them sunday as Ill be doin some panal smoothing in trouble areas Ive spotted.
My924gtc
PostPosted: Sun Oct 03, 2004 11:37 am    Post subject: Reply with quote
Looks good Joe. Looking forward to seeing it painted.
Don't you hate having to hang that front license plate on the bumper. I'm glad MI got rid of that law.
Had I known you were needing to roll your fenders I could have sent you my roller. Probably would have been easier than cuttin'. It attatches to the hub and rolls the lip using a delrin roller.
Oh well, hope you sort everything out soon and get that car one color again.
MJ
'81 924 2.0L T
'82 924 2.3L SC/EFI <---online fall '06
Sponsor of the 944 Cup and Super Cup
Sponsor of the "2006 Battle in the Badlands"
PostPosted: Mon Oct 04, 2004 1:52 pm    Post subject: Reply with quote
yea maybe next time, Im block sanden it a bit now too
as I had some stripes on it before ther yellow was put on and they
were showin up..anyway spent the weekend on it nand heres some pics.
think Im gonna 2 tone it white on top and yellow on the bottem then put some pearl in the clear. Pearls fun you can a little or alot itll turn this yellow into gold and the white into silver if you use enough..
Cut the top lip of the fender off then ground it smooth I then used the
Easy Sand by evercoat its a polyester blending putty in a tube you just add hardener. It sands really easy I like that perfect for block sanden just gotta make sure you take it off only leaven the filled hole dent crater
dip what ever you wanna call it.
PORSCHEV
PostPosted: Mon Oct 04, 2004 9:46 pm    Post subject: Reply with quote
How did you attach the valance to the fenders?? I used to be able to see the lip where they came together...did you just fill it with putty?
1978-#53 "D" track racer.
PostPosted: Tue Oct 05, 2004 6:49 am    Post subject: Reply with quote
No you kidding (not strong enough)
before it was removable held togehter with locknuts now
though its screwed together and unremovable.. I used a piece of nylon mesh tape over the joint in there resin then the filler its been time tested.
with the cut fenders allof my turning radias is back.. nice and tight i canturn around on my street with out curb rash or just plain hitting the curb.
PostPosted: Thu Oct 07, 2004 1:00 pm    Post subject: Reply with quote
Lets see first off theres alot of blocksanden to do plus trim out the front wheel well a bit right at the line where the valance attaches on both
sides it bulges. Contemplating picking up another hood which is more
likely than haven the hood walnut shell media blasted one of the 2 have to happen or do all the sanden its mostly the hood that needs it Im gonna have the top white with pearl and the bottem yellow woth out the pearl
Ill also clear it all maybe (though douteful) add some pinstripe and add
a little pearl in the yellow. I was thinken of adding enough pearl to have the yellow turn gold. Just like a glass of beer.
numbbers
PostPosted: Fri Oct 08, 2004 10:51 am    Post subject: Reply with quote
Well Joe, I have a 931 hood that you can have for fifty bucks, but you have to come back to denver to get it. They cost a fortune to ship. It is in pretty good shape, it just needs a little bodywork on the dings and low spots.
How agout them Bronco's?
PostPosted: Sat Oct 09, 2004 12:39 pm    Post subject: Reply with quote
Yea how about them... If its dry enough this weekend Ill get some paint on
I got to block sand saterday morning with some 220 so If it rains like it is now thats k ..Where supposed to get sunshine on late saterday and sunday
should look good white and yellow... like white lightening.
PostPosted: Sun Oct 10, 2004 2:31 pm    Post subject: Reply with quote
Bought a couple hundred bucks in paint & block sanded
most of the day. Gonna spray on sunday ... pearl white on top
yellow on bottem with clearcoat .. I might add some pearl to the yellow
maybe not alot either just a little I dont know Ill just go with it well see
huh.
PostPosted: Mon Oct 11, 2004 3:44 pm    Post subject: Reply with quote
Might as well provide a pic. The white is on..Im gonna stay home monday and finish it up...
