924 part interchanges
wdb
PostPosted: Fri Dec 20, 2002 10:53 am    Post subject: 924 part interchanges Reply with quote
ENGINE SECTION :
*note : up to flywheel
*VW 4-121 (2.0L 1984 )
*note : change induction and elec. as necessary .
*A
*note :carberated.
*concord78-79 4 -121
*gremlin 77-78 4-121
*spirit 79 4-121
*B (does not specify, by I believe these are 924 N/A )
*76 119hp
*77 95hp calif.
*77 95hpexc. calif.
*77-79 110hp, calif, MT
*77-79 110hp, calif AT
*77-79 110hp exc. calif.
*note :
*fuel injected.
*note :A fits B by switching cylinder head to match induction system and by switching oil pans :
minor modification to cylinder block is required to mount oil pan , compression ratio differs slightly .
*note : B and C interchange.
*porsche 924 76-82 complete
*turbo
*EDIT ;AMC head fits , but camshaft differs and no provision is made for fuel injection .
ELECTRICAL SECTION :
altenator (65 amps)w/o A.C. obs (obsolete )
al99x bosch rebuilt
rebuilt 75 amps w/ A.C obs$128.80
al109x bosch rebuilt 90 amps w/a.c. obs
al115x bosch rebuilt
audi 5000 78-82
audi 5000 83 exc. turbo
audi coupe 82-84 audi quatro 82-84
porsche 924 76-82
vw jetta 82 gas w/oa.c vw rabbit 82 gas w/o a.c.
STARTER MOTOR :
audi 100 75-77
porsche 924 76-82
COIL ;
audi 100 70-73 76-77 MT
audi 4000 79-80
5000 78-80
fox 73-79
porsche 924 76-82
porsche 928 78-83
vw dasher 74-81
COIL for 924 S :
porsche 911 83-88
924 86-88
928 84-88
94483-88
HEATER BLOWER MOTOR :
924 82 86-88 used with squirrel cage
audi fox 77-79 w/o a.c or high output heater
944 83-84
vw quantum 82-88 w/ac
rear wiper motor 924 all
94483-87
steering lock and switch .
TURN SIGNAL SWITCH
L924 81-82 turn signal
86-87 turn signal w/o cruise control
944 83-84 turn signal w/o cruise cont.
WIPER SWITCH
924 81-82 86-87
94483-84
STEERING LOCK
porsche 924 76-82
vw 411/412 71-74
vw beetle 71-79
vw karmann ghia 71-74
vw rabbit 75-76
vw scirocco 75-76
vw type 3 71-73
KEY CYLINDER
all 924
944 83-87
BRAKE ROTOR REAR
924 86-88
928 85-86
CALIPER ASSEM.
924 79 sport front
928 78-82
924 80-82 sport front
944 83 front
REAR
924 79-88
944 83-84
944 +S 85-87
TORSION BAR
R 22 mm
R 23.5 mm
L 22 mm
L 23.5 mm
924 76-82
924 86-87
944 83-87
vw beetle 69-79
vw karmann ghia 69-74
vw thing 73-74
COIL SPRINGS
red (std)
blue (turbo)
924 76-78
924 79-82 exc.sport pkg
924 87
944 83-84
separate from above
924 86
944+S 85-86
STEERING SUSPENSION
LOWER FRONT SUSPENSION ARM
right and left interchange by reversing ball joint
924 86-88
944 83-84
944 85-86 exc.turbo
vw jetta 80-84
vw rabbit 75-84
vw scirocco 75-88
SPINDLE (STEERING KNUCKLE )
924 76-78
79 exc. sport
AXLE DRIVE SHAFT
DIFFERENTIAL CARIER CASE ( I'm unsure about this .
I thought the differential was the pumpkin, posi- traction stuff .
is the 924 differential a separate assembly, and if so will 1 of
these audi diffs. fit to make the 924 a lsd )
audi 100 76-77 5 cylinder
audi 4000 83-87 front axle m.t
audi coupe 82-84 mt
audi coupe GT 85-87 mt
audi quattro 82-87 front axle
porsche 924 76
porsche 924 77-82 exc. turbo mt
porsche 924 86-87 non-locking mt
porsche944 83-86 non-locking mt
porsche 944 83-86 non-locking mt exc. turbo; 8 valve
vw quantum 86 front axle 5 cylinder mt
vw quantum 87 front axle mt
for 77-82 turbo
porsche 911 77-79 930 (turbo)locking
porsche 911 86-87 911 turbo locking
porsche 924 77-82 turbo
for Auto.Trans. 77-82exc. turbo
audi 100 76-77 A.T.
audi 4000 79-82 front axle AT
audi 4000 83-84 front axle 4 cyl. AT
audi 5000 78-87 front axle AT
audi coupe GT 85-87 AT
porsche 924 77-82 exc. turbo AT
porsche 924 86-87 non-locking AT
porsche 944 83-86 non-locking AT
porsche 944 87 AT
vw quantum 86 front axle 5 cyl. AT
for 86-87 924
porsche 924 86-87 locking
porsche 944 83-86 locking
porsche 944 87 MT locking
RING and PINION GEAR
76-77 (31-9 teeth)
77-78 (35-9 teeth)
924 76
924 77-79 Mt
for auto trans
924 77-82auto tr.
38-11 teeth
41-11 teeth
audi 4000 79-81 front axle at
audi 5000 84-85 front axle gas at
audi 5000 86-87 front axle S at
audi coupe 82-84 at
porsche 924 80-82 MT
088 409 143 G
088 409 143 S
37-9 teeth
audi 100 76-77 front axle mt
audi 5000 78 front axle mt
audi 5000 79 front axle gas mt
audi 5000 82-83 front axle gas mt
note ;
porsche 924 turbo 80-82 fits
33-7 teeth
35-9 teeth
37-9 teeth
note
12 bolt carrier
porsche 924 86-88 mt
016 409 143 bf
016 409 143 b
note 3.88 ratio
audi 5000 86 frony axle CS MT
P944 83-84 mt (3.88 ratio)
p944 85-86 mt exc. turbo
p944 87-88 mt 8 valva exc. turbo
porsche 924 86-88 AT
note; 38-11 teeth
audi 5000 82-83 front axle turbo gas
porsche 944 83-84 at (3.45 ratio)
p944 85-88 at
FUEL INJECTION PARTS
FUEL DISTRIBUTOR
porsche 924 76-79 fuel dist. assem.
audi 100 74-77 fuel dist. assem.
WARM UP VALVE
porsche 924 76-82
audi 100 74-77
4000 79
5000 85 turbo gas
fox 75-79
vw cabriolet conv. 85-87
dasher74-81
golf 85-87
jetta 80-87
quantum 82-84
scirrocco 75-85
high altitude 0 438 140 026
TRANSAXLE ASSEMBLIES
porsche 924 76 mt (4spd)
924 77 mt early
note ; the majority of internal parts are
identical to the 76 audi 100 ls
CLUTCH PRESSURE PLATE
porsce 924 76-82 exc. turbo
audi 4000 80-81 5 cyl.
4000 84 gas 5 cyl.coupe 82-84
vw quantum 83-85 gas 5 cyl
quantum 87-88 syncro
TORQUE CONVERTER ASSEMBLY
porsche 924 76-82 86-88
porsche 944 83-89
audi 100 75-77
4000 80-81 5 cyl.
5000 78-81 exc. turbo gas
500 82-83
coupe 82-83
fox 73-74 ( 2 piece axle housing)
vw cabriolet conv. 85-89
golf 85-89
jetta 85-89 gas
scirrcco 84-88
and thats all of it from holender, there was more about the 924S and 944 ,
but you already know it, so I didnt bother to write it out.
