Standard NA front suspension arms
Ventura77
PostPosted: Wed May 20, 2015 9:19 pm    Post subject: Standard NA front suspension arms Reply with quote
Hi guys, I'm rebuilding the front end on my 924, its a standard 4 lug, when I've pulled it down, cleaned it, removed old bushes and such, I had them lightly blasted to ready for paint, but on close inspection of the suspension arms both have a hairline crack right next to the sway bar mounts. What i was wanting to know is can I weld them safely for a fix, because if they are buggered its real hard to find these in Australia. There are plenty for the 85 and on, but they don't have the sway bar mounts
1980 924, having a full rebuild done, worked NA engine is finished ready for turbo, doing an auto to manual conversion, body kit and re-spray, full custon trim and back seats removed
PostPosted: Wed May 20, 2015 10:24 pm    Post subject: Reply with quote
Go ahead and weld them and while you're doing that, add some material along the sides to stiffen them up and bore the new ball joints and holes in the arm for larger, stronger 8mm bolts.
If you need new arms, they are Mk1 rabbit arms with different sway bar mounts (cut yours off and weld them on to the new arms), so that might help your search but won't avoid the welding route.
Good luck!
Ventura77
PostPosted: Thu May 21, 2015 1:18 pm    Post subject: Reply with quote
Thanks mate I'll do that and run some round bar along the edges for strengthing
Tanso
PostPosted: Fri May 22, 2015 4:10 am    Post subject: Reply with quote
New suspension arms are super cheap. I bought mine for 11 pounds each!!!!
http://www.carparts4less.co.uk/cp4l/c/Porsche_924_2.0_1983/p/car-parts/suspension-and-steering/suspension/suspension-arm-and-suspension-joints/?616440038&1&d0d862e74222d57762eabab72f5d6ad28fa5aedb&000320
Our 1983 Porsche 924 project: http://www.924board.org/viewtopic.php?p=364034#364034
brealytrent
PostPosted: Sat May 23, 2015 3:56 pm    Post subject: Reply with quote
The early cars used different mounts for the sway bars, which are much more rare (and expensive).
1977 Porsche 924 - sold
1980 Porsche 931 - sold
1984 Porsche 928 'S2' Euro - sold
2016 Ford Fiesta ST - sold
2009 Porsche Cayman
View user's profile Send private message Yahoo Messenger MSN Messenger
daniel
PostPosted: Sat May 23, 2015 5:19 pm    Post subject: Reply with quote
Mounts are easy to fab onto the new arms, I'll see if I can upload a photo of what I did. Be aware that the manufacturing tolerance is not good. I run nylon bushes that I got through a group buy, one fit nice and snug and the other arm had a mm clearance with the same bush. Had to pack with some shim material
1989 944 Cabriolet
daniel
PostPosted: Sun May 24, 2015 11:39 am    Post subject: Reply with quote
1989 944 Cabriolet
Ventura77
PostPosted: Mon May 25, 2015 8:25 pm    Post subject: Reply with quote
daniel wrote:
By the of the photo the sway bar mounts have been moved outwards from the stock mounts, wouldn't this help to lessen body roll??
daniel
PostPosted: Tue May 26, 2015 3:25 pm    Post subject: Reply with quote
Sway bars are from a 968CS, slight repositioning was required but there is very little in it. Stock set up with rubbers on the drop link would work in the stock position but as I have ball joints this setup gives no binding
1989 944 Cabriolet
