Uh Oh! Timing belt failure, now what?
joejax
PostPosted: Sun Jul 17, 2011 10:33 am    Post subject: Uh Oh! Timing belt failure, now what? Reply with quote
Cruising along today at about 65 mph, suddenly a pop and engine quits. No other noise, just quit.
Coasted off the road, thought I was out of gas, pop the hood to find the belt shredded. Called buddy to tow home about 10 miles (fun).
Been running great lately, hope nothing else is broken. Should I be worried? Have belt and pulley, just haven't got around to change them, yet...
I got nothin'
Uhhh...you got any pics?
PostPosted: Sun Jul 17, 2011 12:01 pm    Post subject: Reply with quote
This is on your 924 n/a?
No worries. It's not an interference engine like the turbo.
PostPosted: Sun Jul 17, 2011 9:08 pm    Post subject: Re: Uh Oh! Timing belt failure, now what? Reply with quote
Guess you will, now!
Martijnus
PostPosted: Mon Jul 18, 2011 12:07 am    Post subject: Reply with quote
I once ripped all teeth off at the highway..
no problem.
924 "50-jahre", 1981.
MSII/extra, LPG, ITB's, 5lug.
To be turbo'ed in a while.
the_mad_electrician
PostPosted: Mon Jul 18, 2011 1:54 am    Post subject: Reply with quote
no problem.
The samething happened to be! I was driving about 75 MPH actually made it almost 3 miles
81 924 N/A
2004 Ranger "Edge"
2005 Mazda 6
PostPosted: Mon Jul 18, 2011 3:24 am    Post subject: Reply with quote
Running with cam timing off can fubar your injectors.
joejax
PostPosted: Mon Jul 18, 2011 5:21 am    Post subject: Reply with quote
Hee hee , Got lucky I guess, stalled on break, able to coast off busy 2 lane onto another road.
Had new belt in car but no tools. Changed today, not too bad of a job, I can see why so many leave that blasted cover off though.
I thought I read on here about a NA motor got damaged by belt failure, so I was worried. I may have been mistaken.
I got nothin'
PostPosted: Mon Jul 18, 2011 8:04 am    Post subject: Reply with quote
Only if you're running really high compression would a broken belt be an issue.
Martijnus
PostPosted: Fri Jul 22, 2011 6:23 am    Post subject: Reply with quote
Mine didn't run ofcourse since it had as much teeth as your average meth addict.
Min
PostPosted: Fri Jul 22, 2011 10:48 am    Post subject: Reply with quote
Or if the broken belt is a symptom of a different issue.
Min
joejax
PostPosted: Fri Jul 22, 2011 12:33 pm    Post subject: Reply with quote
Min
What could be a different issue?
I got nothin'
the_mad_electrician
PostPosted: Fri Jul 22, 2011 12:52 pm    Post subject: Reply with quote
Cam seized up maybe? If something like that happened I think you'd know about it
81 924 N/A
2004 Ranger "Edge"
2005 Mazda 6
PostPosted: Fri Jul 22, 2011 1:36 pm    Post subject: Reply with quote
Broken valve springs is another issue that could cause a valve and piston meeting.
Broken connecting rod, etc.
Both of these issues would be pretty obvious
Min
PostPosted: Fri Jul 22, 2011 3:17 pm    Post subject: Reply with quote
In my case, seized a lifter, broke the cam belt, also broke the cam gear (cracked the hub) etc.
Min
joejax
PostPosted: Sun Jul 24, 2011 10:03 am    Post subject: Reply with quote
Ya'll got me more nervous than a long tailed dog in a room full of rockin' chairs!
Got to take it for a ride today, running OK, may need to adjust the timing a bit though..
Hotter than sacks of ball here, black on black is killin' me, no AC either, really need to get that fixed.
I got nothin'
