caswah
Joined: 21 Mar 2006 Posts: 51 Location: Uppsala, Sweden
Posted: Tue Sep 15, 2009 2:36 am Post subject: Timing belt ripped |
Just fixed my distributor after many hours of struggling.
Bosch sweden sent me an exploded view of the distributor, I took it apart, cleaned it and bent the stator legs even more until there was a gap of almost .5 mm
Reinstalled, timed the engine again and then she fired up instantly.
After running smoothly for 15 minutes it died. I found a piece on the ground. It was one of the L-shaped steel legs holding the engine to the chassis.
Because of the violent vibrations, the timing belt was jammed and ripped off. Im so sick of this. There is absolutely no rust anywhere else in the car except for in that engine attachment. Ripped timing belt is, as you all know, a bit like ripping someones main artery : bad bad idea.
So from one problem to another. Are the valves screwed? The valve lifters ? Is my 924 crap?
Really dont want this  _________________ Euro ´81 924 - Interior being restored |
Slam
Joined: 07 Jan 2005 Posts: 1689 Location: Wainwright, Alberta, Canada
Posted: Tue Sep 15, 2009 2:47 am Post subject: |
Take heart - the 924 is not an interference engine so no harm done, really. The 924S is a different story. _________________ '84 944 - kid blew motor
'80 924 - gone
'78 924 - gone
'77 924 - rusting comfortably |
Rich H
Posted: Tue Sep 15, 2009 3:13 am Post subject: |
What he said. Just replace it, no harm done. _________________ 1994 Lotus Esprit S4 - Work in progress...
Posted: Tue Sep 15, 2009 3:26 am Post subject: |
From your other thread:
| ideola wrote: | | The NA motor is non-interference, so you shouldn't have any worries with valves or lifters. Just replace the timing belt and the tension roller, and you should be back in business. You might consider doing the water pump while you're at it, but not a requirement. |
_________________ erstwhile owner of just about every 924 variant ever made |
Martijnus
Posted: Tue Sep 15, 2009 4:10 am Post subject: |
My belt lost all its teeth at 140km/h.
I only found that out when I had the engine already out, and paid literally 100 times more to rebuild the engine than just replacing the belt and roller.
Well... I actually wanted to rebuild the engine anyway... but it wasn't necessary.
So you should be back on track for a few euro's
Another reason why the 924 is the best car ever. _________________ "Rule: Turbo's make torque, and torque makes fun." (C. Bell)
924 "50-jahre", 1981.
MSII/extra, LPG, ITB's, 5lug.
To be turbo'ed in a while.
968rz
Joined: 21 Aug 2006 Posts: 537 Location: S. E. Wisconsin
Posted: Tue Sep 15, 2009 10:18 am Post subject: |
If you belt breaks rolling down the road at high speed (rpm) even a non-interference motor can bend valves, but at idle or even revving in the garage your safe. _________________ Rick
79 924 coupe Petrol Blue 3spd auto (wife's DD)
93 968 coupe Amazon Green 4spd Tip (my DD) |
!tom
Posted: Tue Sep 15, 2009 10:24 am Post subject: |
| 968rz wrote: | | If you belt breaks rolling down the road at high speed (rpm) even a non-interference motor can bend valves. |
How? _________________ 78 924 NA
5-lug |
Rocco R16V
Posted: Tue Sep 15, 2009 12:31 pm Post subject: |
| 968rz wrote: | | If you belt breaks rolling down the road at high speed (rpm) even a non-interference motor can bend valves, but at idle or even revving in the garage your safe. |
i dont think so. i had a belt break on a non-I vw while driving at high rpm and the car was fixed on side of road and back running within a couple of hours, mostly waiting for brother to get belt n tools and bring it to me.
"non-interference" means with valves completly open crank can be spun without hitting the valves.
but there is some gray area. Adding a big cam or decking the block can change a non-I to an Interference motor. so any non-I motor that is not stock may become an interference motor. _________________ "Government exists to protect us from each other. Where government has gone beyond its limits is in deciding to protect us from ourselves. "
Ronald Reagan |
968rz
Posted: Tue Sep 15, 2009 12:43 pm Post subject: |
Sh1tz moving fast at that speed (rpms), I've replaced cyl heads more that a few times when I was an auto tech because of this. _________________ Rick
!tom
Posted: Tue Sep 15, 2009 12:57 pm Post subject: |
| 968rz wrote: | | Sh1tz moving fast at that speed (rpms), I've replaced cyl heads more that a few times when I was an auto tech because of this. |
So just because valves and pistons move fast means they bend when they get close to one another, but don't hit?
I still don't understand how you think the impossible can happen. _________________ 78 924 NA
5-lug |
968rz
Posted: Tue Sep 15, 2009 2:38 pm Post subject: |
I can only tell you what I've seen (several times); one customer was rolling down I-94 @ 70/80 MPH when the belt let go (non-interference motor), towed the car in I put a new belt on and it runs like crap (miss, back fire...), do a comp test and find low cyl pressure, pull head and find bent valve(s). How would you explain this? This example was a regular customer so I know the engine wasn't some POS to start. _________________ Rick
Khal
Joined: 26 Sep 2003 Posts: 4872 Location: Sunny and lovely interior BC, Canada
Posted: Tue Sep 15, 2009 2:46 pm Post subject: |
Am I missing something here? The cam/valves/pistons/crank/etc... are all travelling at the same rate whether they're connected by the timing belt or not, right? (I mean at the instant the belt breaks, of course) As long as they don't hit each other, what possible difference could it make if the belt breaks?
EDIT: Could the pressure of the combustion stroke bend a valve if it's open and it shouldn't be, perhaps? _________________ '80 924 Turbo |
Min
Posted: Tue Sep 15, 2009 3:09 pm Post subject: |
fill the pockets in your pistons with years of carbon buildup and presto, interference motor.
daniel
Joined: 18 Jun 2009 Posts: 686 Location: Sydney, Australia
Posted: Tue Sep 15, 2009 3:18 pm Post subject: |
Im not getting into the debate of if its possible or not, however what difference does it make if the cars being driven or reved in the driveway ?????
...that being said I have always found carbon to be quite soft once the initial layer goes down..... to the point where anymore than 1 or two layers are blowen away by the combustion process...
Daniel _________________ Over the top of skyline, total brake failure.... hit the wall at over 200 kp/h at the dipper, so anyone who has to brake for the esses is a pussy.
1989 944 Cabriolet |
Duncan
Joined: 04 Nov 2002 Posts: 425 Location: Delft, The Netherlands
Posted: Tue Sep 15, 2009 7:06 pm Post subject: |
I used to carry a spare timing belt in my car toolbox  |
